Necchi 3101 Mechanical Sewing Machine Logo
A
Anonymous Posted on Aug 21, 2014
What do you do if your stitches are loose? I have the tension set at 5
How do you set the tension on the thread?
nystrom_eile
Level 1:
New Friend:
  • Contributor 36 Answers
  • Posted on Nov 19, 2014
nystrom_eile
Contributor
Level 1:
New Friend:
Answers
36
Questions
0
Helped
6189
Points
41
Check the bobbin tension. Good videos on Pinterest.com if you need help doing it.
4 Related Answers
Anonymous
  • Posted on Jan 11, 2008
SOURCE: Machine tension knob does not work.
Use a better quality thread. Sometime old or cheap thread never works right. Check to make sure you have the right needle for your fabric.
bargainbox
Hassy
  • 1388 Answers
  • Posted on Sep 06, 2009
SOURCE: necchi 357 L upper tension will not adjust, have
Zero will be loose.....it is Zero tension ! Try 4 or 5 sor most purposes.
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks
bargainbox.com.au
Anonymous
  • 96 Answers
  • Posted on Dec 13, 2009
SOURCE: The thread keeps snapping after twenty or so
change the needle, if it continues, youe feed dog maybe out of adjustment
Anonymous
  • 1788 Answers
  • Posted on Oct 31, 2010
SOURCE: I have a ramie, cotton, poly, spandex blend of
I would try using some tear away stabilizer under your material and stretching as I sew . If, you do not have interfacing try using some good old fashioned gift tissue paper. Make sure that you are using good thread, Sulky or Guterman, cheap thread is terribly linty and causes build up in your machine.
1helpful
My bottom stitch is perfect but my top stitch is sloppy,how do I fix that?
Is the top thread making a thread mess under the fabric? That usually means the top tension is too loose or the thread is not seated in the tension disk.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning.
Set the top tension at the midpoint and test your machine. Then adjust the tension until the two threads meet in the middle of the fabric.
1helpful
2answers
How to adjust the bobbin tension.
According to the manual, you should not need to adjust the bobbin tension (and I located other sites which stated the bobbin tension cannot be adjusted on this machine). Apparently, all the tension adjustment is accomplished through the upper thread::
"EN Thread Tension Upper thread tension Basic thread tension setting: "4". (1) To increase the tension, turn the dial to the next number up. To reduce the tension, turn the dial to the next number down. A. Normal thread tension for straight stitch sewing. B. Thread tension too loose for straight stitch sewing. Turn dial to higher number. C. Thread tension too tight for straight stitch sewing. Turn dial to lower number. D. Normal thread tension for zig zag and decorative sewing. Correct thread tension is when a small amount of the upper thread appears on the bottom side of fabric. Lower thread tension The bobbin tension has been set correctly at the factory, so you do not need to adjust it. Please note: - Proper tension setting is important for strong seams. - There is no single tension setting appropriate for all stitch functions, thread or fabric. - A balanced tension (identical stitches both top and bottom) is usually only desirable for straight stitch construction sewing. - 90% of all sewing will be between "3" and "5". - For zig zag and decorative sewing stitch functions, thread tension should generally be less than for straight stitch sewing. - For all decorative sewing you will always obtain a nicer stitch and less fabric puckering when the upper thread appears on the bottom side of your fabric. 1 A B C 22 D"
Doing further research, I found this statement on a machine review site:
"After reading reviews online from where I've bought my drop-in bobbin machines, I think many of the negative reviews are due to the bobbin thread coming up without laying across the bobbin. It can cause the stitches to look very sloppy and no amount of tension adjusting can fix the stitches."
There are several machine review sites wherein 4423 owners stated their disappointment in the 4423's performance. Some said the machine failed almost immediately and others said the machines developed problems when sewing heavy fabric.
How do i set the tension
FIRST... make sure you are threading the top thread correctly
Then... make sure your bobbin case is threaded correctly
This sounds backwards but this is how it is done. If the bottom of your stitching looks loose, you need to tighten the TOP thread tension. A setting of 5 is normal, but if the bottom stitching looks better at a higher or lower number... go with that.
?The top stitches are fine; the bottom stitches are very loose.
Firstly check the tension on your bobbin case is sufficient or if the thread is actually into the spring fully, this is most likely cause of bottom thread loose stitching. You can test bobbin case tension adjustment using the "Dangle" test, here is a link to some good images to help.
http://www.sewusa.com/Sewing_Machine_Repair/Thread_Tension_Settings.htm
If you look closely and there is actually looping on the underside then is is the top thread coming to the underside and not being tensioned back up; so top thread is not under tension enough or at all.
Set top tension to 4-5, then recheck the threading up and and always thread with the presser foot raised as this opens up the tension device so the thread can seat in fully. Once you've threaded to just before the needle thread guide, lower the presser foot and pull the thread downwards, it should be very firm if its under tension.
Tension devices can get gunked up or fail with use so if you can't get it to feel firm, it will need a technican to investigate further.
1helpful
Stitching very loose
thread is not under tension correctly. Check bobbin is under tension and that the top tension dial is set to a mid number ie 5 if it goes from 0 to 10.
Check thread is pulled between the tension discs fully and is correctly threaded.
4helpful
The thread underneath when sewing is too loosed
Usually thread too loose on the bottom is caused by the upper tension being too loose. The top and bottom tensions work together with the top thread making the underside of the stitch seem too taunt or too loose and the bobbin thread causing the top side of the stitch to be loopy or too tight. Select a large zig zag stick and sew a couple of inches. Then examine the stitch. It should look identical on both sides. Look to see which side is drawn too tight, the zig zag being smaller on that side with threads from the bottom threads pulled through. Then adjust the two tensions so that they make a uniform, identical stitch.
Also, when the bobbin tension is right you can hold the bobbin dangling by the thread and it won't spool out to the floor but will let loose a bit with a slight flick of the wrist. Too loose it will just spool out. Too tight and it won't drop at all. When you get that set right then do the above zig zag test to see where the top tension should be set.
I think I have a tension problem??? I'm sewing a straight stitch but the underneath stitch is loose.
Try re-threading the top thread with the presser foot raised so the thread is properly set in the tensioner, and the tension should be set in the 4 to 5 range normally. Then make sure the presser foot is lowered to apply the tension to the upper thread to sew
~<Ray>~.
Pfaff varimatic 6091 sew a rag quilt with jean and flannel,I can't get my tension right it seems to be funny on the bottom stitch,where shoulf the top tension be set at 4 1/2 ,when do I adjust the bobbin...
Hi! The bobbin tension rarely needs to be adjusted. First, make sure you're using the appropriate size needle and thread for your fabric (I'd probably use either a 'denim' needle or a universal size 14) and also that the upper thread and bobbin are threaded absolutely correctly. These can throw off the tension! Also, take the time to clean out the bobbin area. That can throw your stitch off also.
If the stitch on the bottom is loose, so that you see the top threads, then the top tension is too loose. If the top stitch is too loose and you see the bobbin threads on top, then the top tension is too tight.
It helps to thread the machine with different color thread on top and in the bobbin, and then stitch an inch or so on the same type of fabric as you're using in your quilt. Check the stitch. If you need to adjust the top tension, make sure the pressure foot is down! Adjust a little, stitch a few inches, and check again. Repeat until you don't see any (or very little) bobbin thread on the top or top thread on the bottom.
If you go through all these steps, and the bobbin thread is still loose (and you've tightened up the top tension), then there is a tiny little screw on the side of the bobbin case that you can use to adjust the bobbin tension. Turn the screw just a little bit (less than a quarter turn), stitch, check, etc. Once the bobbin tension is set, you shouldn't ever have to change it.
Let me know if this helps, ok?
Happy sewing!
Tension settings for husquvana daisy
Your machine tension should be set between 3-5. If your stitch is too loose on the bottom, you can try to up the tension a little at a time. You can also check to make sure that your machine is threaded properly and also check the tension and make sure there are no threads wrapped up inside the tension between the tension discs.
1helpful
Tension on stitches
Loose bottom stitches mean the UPPER tension has a problem. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it does not work this way( the tension stays loose) you will need to set the tension to Zero, open the discs with a small screwdriver and remove the lint or thread which is stuck in there.
Sewman7
Top Necchi Sewing Machines Experts
vince
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
