HP LaserJet P3005n Printer Logo
A
Anonymous Posted on Aug 19, 2014
50, 4 FUSER ERROR - HP LaserJet P3005n Printer
Mark Schmit
Level 3:
  • HP Master 1,915 Answers
  • Posted on Aug 20, 2014
Mark Schmit
HP Master
Level 3:
Answers
1915
Questions
0
Helped
754077
Points
7967
50.4 is not listed in the service manual but fuser errors are most often caused by bad fuser. Occasionally a power supply or DC controller will fail but seldom is that the case.
1 Related Answer
Anonymous
  • 226 Answers
  • Posted on May 21, 2012
SOURCE: 50.a fuser error
Change the fuse!!!
Hp 4m shows service error 50
The service 50 error indicates a bad fuser assembly. You can get one on Ebay for less than $50. To replace the fuser just open the door on the back of the printer, inside you will see the fuser, unscrew the 2 screws and pull the old one out. Insert the new fuser and screw it down, power on the printer and you should be good to go.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
[email protected]
1helpful
Error code- 50 service
Hi Sheila,
The following page gives the reason http://www.all-laser.com/cgi-bin/webc.cgi/error50.html
Seems the printer needs something called a fuser. There is a link to maintenance packs including the fuser or just the fuser alone.
Fuser 50.1 error on HP 3500 printer
From HP Website:
50.X FUSER ERROR Description A fuser error has occurred. Action
  1. Turn the printer off.
  2. Verify the fuser is properly installed and fully seated.
  3. Turn on the printer.
  4. If the message persists, contact HP Support.
HPLaserjet4P - printer service 50 -
A 50 Service error is a fuser error. Turn the printer off for 5 to 10 minutes, then turn it back on. If the error is still there, I think your going to need to make a service call you can try reseating the fuser, but be sure to let the fuser cool completely before touching it.
Good Luck the HP Laserjet 4p is a great printer.
1helpful
50 service flashing on display screen
If the display panel reads 50 FUSER ERROR, CYCLE POWER, turn the printer off for 15 minutes. This allows the capacitor that is responsible for signaling this error to discharge. If you don't wait 15 minutes you will continue to get this error even if you have replaced the fuser. If it continues to show the error, then you need to replace the fuser. It is easy to replace.
The fuser maintenance kit is about $119. on the web.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
2helpful
3answers
Hello
A 50 Service error is a fuser error. Turn the printer off for at least 10 minutes, then turn it back on. If the error is still there, you can try reseating the fuser, but be sure to let the fuser cool completely before touching it.
If you still have the 50 Service error after reseating the fuser, you might need a new fuser.
You can access the fuser by opening the rear door. It's located directly above the paper tray. There are two screws that hold it in place. Remove those two screws, and the fuser slides outs.
Hope this helps.
Error 50
Error 50 is a fuser unit fault code. You can take apart the fuser unit and see if the fuser lamp is functional. Also check some of the other thermal parts on the fuser. If everything checks out, you will probably have to replace the thermistor. You will need to see if it will be cost effective to replace the necessary parts (Brother parts are not cheap), or to buy a new printer. Hope this helps. Good luck.
k24674
Grand Canyon Tech
Grand Canyon Tech
