Honeywell | Ademco LYNX Plus   LYNX Plus Logo
A
Anonymous Posted on Aug 17, 2014
How do I remove 103 check lngrng radio error message
How do we fix?
Bowei Hsu
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 24, 2015
Bowei Hsu
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4922
Points
5
Go to programming using [installer code] +8 + 00
then enter:
*41*
*42*
*55 0
*94*
then exit programming with *99
If you don't know your installer code, you may try 6321 or 4112. I think 6321 is the default.
I have enter below codes for my Lynx plus to disable the code 103 check.
6321 800 *41* *42* *55 0 *94* *99
  • Brandon C
    Brandon C Aug 26, 2016
    Once your in programming mode, * followed by two numbers brings up a setting ( except *99 thats to exit programming mode ) once your in a setting, you have to give it a value in order to make a change. The only value given for any setting above is 0
Ed Dionne
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 24 Answers
  • Posted on Dec 18, 2014
Ed Dionne
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
24
Questions
Helped
15545
Points
26
Im not familar with a lynx unit but you should be able to go on line and find out. You could also call honeywell and ask for tech support..
Ed
  • Brandon C
    But I am "online" and did not find out.
1helpful
What is the following error code 103-372
103-372: IOT sc S/W Fail
An error is caused when processing the software in ESS PWB, and the process cannot be continued after that.
Replace ESS PWB
(Electronic Sub System Printed Wiring Board)
2answers
What can i do to fix the error message from my jaguar radio
the radio may have been removed or lost power to the internal battery. you may need to contact Jaguar to get an unlock proceedure for it and possibly an unlock code as well.
D-link DI 524 Router (Quick Router Setup - error: 103)
Hi! this is Alex Walker expert to help you for this issue call me on +1(518)348-9393 I will be glad to assist you Thank You
1helpful
Sc:542 error message on the screen
You need a firmware update…
SC542 SP1-103-2 Off + Temp has been newly added to prevent SC542 from occurring at machine power-on under low-temperature conditions.
Note: For this fix, it is necessary to use Controller firmware ver5.15.1 or newer.
It says 103 on my alarm system
Check 103 on Ademco alarm system would usually tell me that you had your back up radio upgraded, but installer did not remove old back-up radio properly. If this is the case service call sould be or would be free.
3helpful
Dlink router error 103
i cant open any video online , like see any movies or and signal online , it is give me erroe 103 how i can do it
1helpful
2answers
Printer C760
This error normally requires a service call. However, certain rare occurrences, such as a stray static discharge in the vicinity of the printer or a power fluctuation, can cause a false 103 ITU error message to appear. If possible, connect the printer's power cord directly into a grounded wall outlet. In rare instances, a surge protector or uninterruptible power supply (UPS) can generate false error messages.
Top Honeywell Home Security Experts
Jay Finke
Jay Finke
deton8 von Splosion
ADMIN Andrew
ADMIN Andrew
Are you a Honeywell Home Security Expert? Answer questions, earn points and help others
