SOURCE: I don't have an instruction manual for my Seagate 160 GB External
Well, if it is a USB Drive, you can locate the drive on your Computer. and using Windows explorer would be a lot easier, click on start, all programs, accessories, Then click Windows explorer, and on the left hand panel, you can then search your drives and located the data that you want to copy and paste. For example, I am going to copy my documents from my (C:) drive, and I then will paste onto my USB flash Disk Drive (J:)..you will see the files go from (C:) to (J:) drive once you start the process...thats it!
SOURCE: Seagate Free Agent Drive cannot be modified? Worked before...
Ok,
Sounds like it's one of three things then
Disk trouble from unplugging the usb while the unit is still "running" and not yet finalized. Running CHKDSK /? /F in the run box where ? = extrenal drives lettrer. Then restart the computer(done from windows PC with drive attached)
Shell trouble I have already advised a dozen or so people this week that if CHKDSK doesn't work, replace the shell with a new one and see if the hard drive works in the new shell.
Failed harddrive, of course this is always an option. If neither of the above suggestions works then it's possible the hdd has failed and you may need to send it to a pro if you have any files on it that need retreiving.
Hope this helps FixYa, if you need additional help just reply to this by adding a comment.
Chris
SOURCE: how do I transfer data from my hard drive to added external drive
you can this many different ways. The most straightforward is to go to the drive and select "folder and file options" in the view menu and selct "show hidden files", that way when you copy and paste you will get every single file. The other way is to use a program such as Acronis Tru Image and use the clone option. I am assuming that you want an image of your C:\ drive.
SOURCE: Using hard drive on a Mac
Have you accessed it in the disk utility? ( applications-utilities-disk utility) try running repair disk first (select the drive first though) then repair permissions (on both the external and main drive)
SOURCE: How to transfer data from
You need a usb cable to harddisk. than a computer running linux. connect hd by usb to linux and copy.
