Drain
SOURCE: Ge Profile Harmony Washer doesn't drain properly.
It sound like you have a blocked pump. Remove the pump from the machine and check where do you have this clogged, inside the pump or in one of the pipes connected to it. Good luck!
SOURCE: HELP, GE profile harmony washer wont drain properly
If you remove the tub to pump hose from the pump and try to turn the pump impeller by hand, it should turn freely. If it does not turn freely, then the motor could be seized and you will need to replace the pump.
SOURCE: Will not spin drain properly with or without clothes.
It won't drain
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
It doesn't spin
It doesn't pump or spin
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
It pumps, but doesn't spin
If your washer pumps out the water but doesn't spin, check these:
It spins only with the lid closed
For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
SOURCE: my ge profile harmony will not spin and drain
I AM NOT A MECHANIC (THOUGH I WISH I WERE), BUT IT SOUND LIKE YOUR BELT OR MOTOR COUPLING. I DON'T WANT TO TELL YOU WRONG. I AM NEW AT THIS STUFF. I HAVE BEEN AROUND WASHERS ALL MY LIFE TO KNOW WHEN THEY BREAK DOWN AND NEED TO BE REPAIRED, BUT MY DAD (WHO DIED IN 2006), SPENT MOST OF HIS LIFE REPAIRING MINOR PROBLEMS ON WASHERS. GOOD LUCK.
RODNEY
SOURCE: We have a GE Profile Harmony washer, it just ran
Along with checking the drain hose, check the drain port from the tub, something may be blocking the drain and no able to get into the tub, or it may be sucked into the pump.
What can happen with a fully loaded machine is, for example, if a small sock happens to be at the top of the load when the spin starts, it can be flung in between the inner perforated drum and the outer. If this gets down to the drain, it may block the drain hole and stay in the drum. It also could get sucked into the drain hose and stay there, or actually get into the pump ... My vote is that it's in the pump, if the pump is humming.
Give it another look.
