5.7L
no code told, why skip the most important fact?
P03xx (what is the XX)
code 300 is means all cylinders misfire,
301,to 308
my wild wild guess is P030x code
this misfire, means, this. in TRUTH
that cylinder has bad combustion. (means weak only or dead)
caused by 3 things.
1: bad spark plug. or wires to it. or cop coil if is.
2: bad injector.
3: bad compression this cylinder or water or oil landing here.
3b: bad cam lob on X
3c bad piston on X cracked,.
3d, valves burned, X
and more, even cracks in X. all things inside X
the service manual is online
https://eautorepair.net/Marketing/Default.asp
the injectors all have a 12vdc power rail to a fuse. 5.7L/4.7
as do all 8 COP coils. (i bet one is bad or just boots to it bad))
all 8 injectors use that one 12vcd fused feed line
these are called PnP injectors. 12v, 0v, 12v, 0= fire.
the coil on X unstated injector is about 12 OHMs , no not zero nor infinity a super basic test that
moving the injector if bad, (side swaps) the TDC error moves with it.one more basic test.
a simple NOID lamp test shows if the PCM is firing it.
here is the schematic in part.
now all tests a short list
All fuses good , not guessing testing./
spark plug good on X
spark COP boot replaced, $15 cost, cheap on X
compression on X passes
spark tip not soaked in OIL or ANTIFREEZE on X
Injector ohms out good and NOID lamp passes on X
the injector and COps run off fuse #10- 30amps.
if blown the ASD relay is dead, so fuse 10 is not dead
because ASD is closed now and engine runs. (no stated be inferred)
bad engine, bad spark or bad injector, on cylinder X
X not told.
there are other possibles. like cylinder X has a vacuum leak
in Intake X port, gasket cracked, lean burn misfire.
leaking injector
we do the FSM (SM) book injector leakdown test and balance test to find that.
and more. ask for more tell what X is?
