20 Most Recent Yamaha Waverunner Xl 800 / Xlt 1200 Jet Ski Pwc Cover Questions & Answers
2answers
Yamaha torque specs
The owners manual does not provide torque specs there is an on-line manual for $5 which claims to cover torque specs at: https://www.tradebit.com/filedetail.php/141315359-yamaha-waverunner-gp1200r-service-manual-repair-2000-2002 Good luck!
7/10/2021 8:06:11 AM • Yamaha... • Answered on Jul 10, 2021
Where is the port into which I spray fogging oil to winterize engine?
You'll see 2 small caps in the carburettor cover. Do that fogging only in very well ventilated area ( outside thus). Run the engine on idle, open both caps, spray as much fogging oil in both holes ( use 2 cans) till the engine stalls. Close the caps. Done...
11/14/2017 9:57:54 PM • Yamaha... • Answered on Nov 14, 2017
95 Yamaha super jet 700
Have you tried without fuel tank cap? Seems to me as a fuel delivery problem...
11/14/2017 9:40:39 PM • Yamaha... • Answered on Nov 14, 2017
1993 waverunner bogging down on take off. New rebuilt carb, will low oil level cause this? Is there a low level switch /?
Only of you have ran the engine out of oil...Sounds like the carbs may not be set correctly.. .Did a professional do the rebuild?..What exactly was "rebuilt".. were any parts replaced? Sounds like the low speed (pilot jets/air screw passages may not be clean as they need to be??) Please check the compression on each cylinder..remove the spark plugs... hold the throttle (carbs) wide open when you check this.. spin the motor for 5-8 seconds... you should get 120psi. minimum..(and less than 10psi difference).. if less, it might be time to actually rebuild the top end..(new pistons/rings/hone cyl.).. only bore it if absolutely necessary.. get it measured.. There are only 3 parts in a two-cycle carb that ever need to be replaced,,(unless they are actually broken) The needle and seat assy., the jet needle and the needle jet. ..see pic... parts # 41 = needle and seat assy. #6 = jet needle, #37 = needle jet. tm_flatslide_expl-bzhe2oey0b0e11an1gziaszn-4-0.gif The needle and seat regulate the flow of gas into the carb as the floats rise and fall..,, if they are damaged or leaking the carb will overflow with gas., the needle jet is a orifice with a specific size..The jet needle has a specific size, taper, and length..== The jet needle and needle jet work in unison to regulate the flow of gas from right off idle all the way to WFO..the needle jet/jet needle WILL wear over time causing the fuel/air mixture to become richer and richer and start fouling spark plugs..(this is more pronounced on 4-cycle ATV's)... I hope this has shed some light on your carb situation... Good luck... exploded view of mikuni carb Google Search
7/12/2017 2:12:24 AM • Yamaha... • Answered on Jul 12, 2017
2answers
What is wrong with my wave runner
Make sure you are using Yamaha oil not an off brand. It does make a difference.
7/7/2015 8:37:01 PM • Yamaha... • Answered on Jul 07, 2015
How to remove exhaust
Do you have a 1200 xlt ? If yes then undo the 2 large jubilee clips on the top of the exhaust , slide it forward to access the next 2 clips on a smaller pipe , slide this forward also ! Then remove the 2 clamps on the top of the cylinder head , remove the spark plugs or they wont come off and put rags in the plug holes ! Then below where the clamps came off there are 2 bolts down between the engine and exhaust to come out , then at the rear of the engine there is another clamp , totally remove it also ! Then release the clip at the point where the exhaust goes through the bulk head and you should have a sencer wire in the exhaust , unclip it and you can then pull out the exhaust with a bit of push n pulling ! the front part of the exhaust has a water pipe under the front part and then the bolts on the manifold which the outer ones are tight against the body but you only undo and remove with the exhaust , tight squeese ! Refit in reverse order !!
2/25/2015 2:16:39 PM • Yamaha... • Answered on Feb 25, 2015
Covert1052cc to h.p.
Size does not convert to h.p. You need RPM, compression ratio, efficiency, crank shaft length, number of cylinders and efficiency, valve spring force constant, valve weight, and many other variables. Horsepower is normally measured with a dynomometer (dyno). It is not calculated.
8/30/2014 12:30:02 AM • Yamaha... • Answered on Aug 30, 2014
I have no spark , fuse is good , maybe bye pass code ?
Check the ground wire from coil to engine & the plug wire that it doesnt have any cracks which could make it short out or try another plug as they can become faulty...there is no fuse in the sparkplug wire
8/10/2014 3:37:11 AM • Yamaha... • Answered on Aug 10, 2014
Relay replace starter
if its xlt 1200 its inside the big black electric box at rear of engine ! unbolt it and remove the back cover !
6/11/2014 11:35:40 AM • Yamaha... • Answered on Jun 11, 2014
I have a Yamaha 1100 2008 waverunner. I am concerned about the water flow at the back. It is rather slow. I check the inlet and impeller and see no obstruction and the impeller turns with no pressure.
run on hose adapter and check engine is cooling by feeling the engine and exhaust system ! if ok then check intake water pipe is clear ! 2 or 4stroke?
6/9/2014 11:29:17 AM • Yamaha... • Answered on Jun 09, 2014
2answers
How to fix a water port?
possible seized water pump the one that is not working follow it back to the source look for blockages but personally i cannot see a blockage stopping all water coming out so i would look more at the water pump
6/6/2014 8:53:20 PM • Yamaha... • Answered on Jun 06, 2014
which make of jet ski have you as all different ??
6/2/2014 2:22:38 PM • Yamaha... • Answered on Jun 02, 2014
Yamaha Waverunner Xl 800 / Xlt 1200 Jet Ski Pwc Cover Logo
Popular Tags
36 questions posted
Top Yamaha Boating Experts
neil
Stan Ford
Are you a Yamaha Boating Expert? Answer questions, earn points and help others
View Most Popular
Yamaha Boating
  • Yamaha Boating
Most Popular Question
yamaha waverunner 1200 tripple 2004
  • Boating
