There is no pressure coming from the water port in the front of the toilet to push waste down
That's an interesting one! Does the flush valve close properly so the tank can refill? Does the float valve allow the tank to refill fully, to near the top of the overflow? That can be adjusted, if it doesn't.
Check fhe flush valve - you may have an obstruction under it. Also check the water port from the bowl side - feel up inside the port for obstructions or buildup of hard water deposits.
WASH YOUR HANDS THOROUGHLY afterwards.
SOURCE: Kohler Cimarron elongated comfort height toilet not flushing correctly
low water in the bowl is only caused by the float being to high! the gurgles is Usually because of air coming back up through the pipe, check your vent pipe that come out the roof. this will help the draining.
SOURCE: My new K-4632 AA toilet flushes fine and refills
Hello. Your toilet is leaking through the flush valve. This is a serious issue as it will use a huge amount of water every day. Check to be sure there is not an obstruction in the tank and if you can not find one, call the plumber. J.
SOURCE: My Kohler toilet tank is
Change out the ball **** and float assembly and flapper valve to one of the newer types...
Also you can set the level of water in the tank by an adjustment screw located at the top of the ball ****.
The Flapper valve on the bottom of the tank also needs replacement, that is causing the tank not to drain properly.
This is a free answer, please rate me
