Let someone use and and they got spackle and sheetrock dust all over it and on the blades. need to clean it. Can I use a hose to spray it down
SOURCE: replacement fan blade for fan
I have one of these pieces of junk. The motor swarmed, so the rest of the fan is perfect. I'll sell it for $10.00 plus shipping.
Skip [email protected]
SOURCE: Blade for Patton Stand Fan Model 1010-MP1
u can get a replace blade from hard wares and fan shops also try ebay and oztion
SOURCE: need fan blade for patton model u2-1887
it would be far cheaper and more easy to replace the entire unit
SOURCE: cleaning of the fans
When I called Seville Support I was told that you can NOT open fan to clean and may not get it together if attempted (glad I stopped when I did!).
You need to use air pressure. After using much of a can of compressed air such as you would use on a keyboard and not getting too far, I broke out my seldom used air compressor which kicked out enough dust bunnies as to block out the sun. Hint: be sure to use outdoors. I'm happy to report both units working as good as new.
Don't have an air compressor? Ask your neighbor, he'll need the correct nozzle to 'blow air' (it comes in handy for many tasks).
SOURCE: How do you clean Patton Floor fan?
The grill is in two halves with the back half attached to the motor. The front with the round patton insignia removes easily by applying leverage with a screwdriver. There are eight spots (at least on mine) where it clips. Be sure to remove any disposable plastic fastener holding the two halves together. Its pretty easy.
