The "E18 Sensor Alarm" is displayed when malfunction of sensors occurs. Check whether the cables between Control PCA and sensors are damaged and also check all the connectors are connected properly.
For detail code 1b, check Ultrasonic (US sensor)
For detail code 11, check Pick Sensor
For detail code 12, check Imprinter Top Sensor
For detail code 13, check Read Top Sensor
For detail code 14, check Exit Sensor
For detail code 15, check Reject Sensor
For detail code 17, check Skew Sensor
If the issue persists after checking the above, then you may have to replace the sensors and PCAs.
Hope the above information is helpful.
Thanks & regards,
ScanCare
You need the detail code after the display has posted the E18.
This can be achieved by holding down both thickness keys down,
Reject Sensor would read o15 for example.
The favorite is o14 Exit Sensor (top middle right on exit)
especially on the pre mod units dated 2001 2004.
Regards [email protected]
