Mounting bracket
Found it ! Take a knife and peel off the Compaq logo on the back. The other 2 holes are underneath !
Refer its user manual for fitting details. Gopakumar Gopalan Google
SOURCE: We have everything connected in our monitor but
Hi there!
I could post the whole solution here but I found a link that could direct you to an illustrated solution:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01289551&lc=en&dlc=sk&cc=sk&lang=sk&product=3351970#N367
I Hope this helps!
SOURCE: Using a Compaq WF1907 monitor with a Playstation3
No. HDMI transfers picture and sound, but DVI does not. You need a audio line as well.
SOURCE: Cannot install: HP Compaq WF1907 Wide LCD Monitor Update.
I found in the folder of Hp the file that does the " UPDATES".
So, thanks for the offer to help me, but all is well now with me and the Hp UPDATES.
Regards
Frank
SOURCE: I'm receving "disk boot failure" error. Compaq wf1907 monitor
if your computer has a floppy drive and you have inserted a disk, remove the floppy disk and try booting again.
if this is not your case you can try out a couple of things
1. Check the CMOS of your computer
To do so
- Boot your computer and on the manufacturers logo window press F2 or Delete depending on your computer.
- In the bios check for the availability of a hard disk drive under the storage category if it exists look for the boot order window or menu. check i your hard disk is enabled for booting in this page.
- If all the other methods do not work and your OS is Win XP you can reinstall it in repair mode. Otherwise it would be better to visit your nearest service store.
SOURCE: Compaq WF1907 19" monitor backlights are on, but
Check the monitor on another computer to verify if using correct setting for this monitor will allow a clear image to be displayed.
In windows 7, the monitor should be detected and installed automatically.
What version of windows are you using?
