SOURCE: Stop Motion Knob
Dear Jim,
I'm sure you have a pair of Channel lock pliers around.Place a fairly thick piece of fabric around the inner knob to keep from scratching it. Grasp it with the pliers while holding the handwheel and turn it to the left. IF you can't hold the wheel to keep it from slipping, place a screwdriver or something else under the needle set screw area, turn the wheel until the set screw is resting against the set screw and then turn the inner knob with the pliers.
sewman7
SOURCE: I need a manual for this machine
go to singerco.com and in the drop menu pick instruction manuals then in the model number put in w 1418 and it will bring up a free manual. I lost my manual and a friend suggested this and it worked good luck
SOURCE: white 1418 sewing machine
If you have taken the hook out that is the half moon shape first of all make sure the needle is at the top of the machine, hook in, gate up and that is all there is to it.
