SOURCE: ONAN 4000 RUNS FOR ONE HOUR AND DIES--ANY IDEAS WHY?
If your unit is running fine and then all of a sudden it just shuts down it is usually that you stopped creating voltage. You need to check the brushes and rings. If you are able to start the unit right up without any hesitation and voltage is being produced, then your fuel pump is breaking down. If you do have hard time restarting then you may have clogged fuel filters. One at the carberator and one at the fuel pump.
SOURCE: honda eu 6500 gen overload indicator light will not shut off
Check the Ground Fault Indicator circuit breaker for triping, and look for the high limit on generator. Reset the main breaker by triping it full right and then back. Vitally
SOURCE: I have a 3cylinder kubota diesel generator and the
one of the valves is not closing properly presurizing the crank case and creating an oil mist get some one to check the valve clearances before you kill probably the single best (non turbo) diesel engine on the planet Good Luck
SOURCE: onan 30 DDA dieasl john deer gen runs great for
its seising up ,the oil is not getting round properly,blow out all pipes with a compresser,or its over fueling
SOURCE: Onan Generator stopped working in motorhome
Yes it wil not let you run your motorhome out of fuel they set it up that way so you dont strand yourself you may have a air bubble in the fuel line to the generator try blowing air generator fule line back into the tank
