I cleaned the condenser, pulled back the covering, pulled back the wiring so I could Get enough duck tape over the to keep from flooding the trailer. I pulled one wire off so I could get enough length together in there to cover hole. Is sprayed my non duck corrosive cleaner and washed it out. Put it back together, used silver tape over seams , now it will not start, fan or ac. Where would I find the model number for this Coleman unit
Is there not a wiring diagram right on the inside of the door. Your question is all over the place, the condenser is not going to flood the house and has nothing to do with the fan. Slow down a little bit and edit your question.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
SOURCE: COLEMAN A/C mod. 2436-901 compressor
I am sorry to say this but there is no wiring diagram/service manual avaialable anywhere for this model.You can contaact Coleman at their main support no. 877-726-5362 and ask them to email you a copy of service manual.
By the way here is a diagram for your A/C but its not a wiring diagram.Just in case if you want to know about the parts scroll you mouse on the diagram.Please CLICK HERE
Please don't forget to rate or accept the solution.
SOURCE: i need wiring diagram for an old coleman suncutter/whole house a/
yeller cool
red common
white heat
green fan
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: We have a Coleman 7300 rooftop ac unit. When the
The fan motor is getting hot and going off on the internal overload in the motor.
This is caused by either a low voltage, a bad capacitor, or tight or dry bearings in the motor.
To check the bearings turn the power off to the unit, then spin the fan blade if it spins freely then the bearings are ok.
To check the capacitor you will need some kind of
tester or you can buy a capacitor and replace it, that's what a lot of people do. They usually don't cost very much.
To check the voltage you will need a voltmeter and measure the volts at the unit.
SOURCE: I need the wireing diagram for a coleman rv/ac
If it is mechanical controls at ceiling, this link should be it. It's a service manual, but has what you need and more.
http://www.rvcomfort.com/pdf_documents/1976141_copy.pdf
If that's not yours, try ( http://www.rvcomfort.com/rvp/rvp.php ) and go to technical information and search for yours.
