20 Most Recent Coleman Electric Cooler 40 Beverage Cooler Questions & Answers
4answers
I have the coleman 40 qt cooler model 5645. The
it is a 60 x 60 x 10 mm 12 volt dc cooling fan available at most computer part suppliers search ebay for 60x60x10mm 12 volt fan
1/8/2023 3:56:04 PM • Coleman Electric... • Answered on Jan 08, 2023
2answers
Coleman model 5645 inside fan motor not working
pull straight up on the cover. Remove the 4 screws that hold the fan to the heat sink. You can then remove the 2 torx screws and remove the heat sink if you need to. Clip the wires as close to the bad fan as possible so you will have enough for the new fan.
7/29/2019 2:34:51 PM • Coleman Electric... • Answered on Jul 29, 2019
2answers
My coleman 40 qt. powerchill keeps freezing up
This is normal due to humidity, It means your cooler is working well.
10/9/2017 3:30:25 PM • Coleman Electric... • Answered on Oct 09, 2017
Hi the cooler is on but not cooling
Sadly, it may have lost its refrigerant charge. Happens sometimes when they're jarred around a great deal or dropped.
5/12/2015 6:46:07 PM • Coleman Electric... • Answered on May 12, 2015
0answers
0answers
2answers
Cooler freezing up
The system is most likley working fine.
The problem is moisture in side the unit. It needs to be dry inside or ice will build up on the cooling unit. make sure the lid is fully closed also.
2/19/2014 4:36:24 AM • Coleman Electric... • Answered on Feb 19, 2014
Coleman Electric Cooler 40 Beverage Cooler Logo
68 questions posted
Top Coleman Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Coleman Home Expert? Answer questions, earn points and help others
View Most Popular
Coleman Home
  • Coleman Home
Most Popular Question
looking replacement motor
  • Home
