SOURCE: I have attachments (Mincer and
Hi ...
all Attachment for models A700D. A701 / A , A702, A703
NOT fit in models A900 ahead
anyway, the front of kenwood A900, and KM series its same, you can fit, but not of the models A700/701/702/703C
in http://www.kenwoodchefrestore.co.uk
you can see the compatibility of attachments
Regards
SOURCE: hi, I'm from Malaysia.I have
Hi from the Philippines and welcome to FixYa, I am Kelly
Is it just the power whisk or all attachments that do not rotate? On the A701A there is a clutch and spring fitted to the gearbox. (Spring loaded clutch) There is a pin in the cover that actuates the clutch. If the pin is broken or come out of the cover then the front of the machine will not work. (you may have to have someone fabricate a new pin!) If the clutch spring has broken you will experience the symptom you described also.
There is also a belt from the motor to the gearbox and the belt may have broken or come off.
The belt can be found on Ebay here:
http://cgi.ebay.com.sg/KENWOOD-CHEF-MAJOR-GENUINE-TOOTHED-RUBBER-BELT-197944-/200565225066?pt=UK_Home_Garden_Kitchen_Mixers&hash=item2eb29e766a
Thanks for choosing FixYa,
Kelly
