20 Most Recent Kenwood KM300 Chef Stand Mixer Questions & Answers
Having done it the hard way (!) it is dead easy. All you need is a small screwdriver or similar, approx 2mm by 1mm in cross section. Looking from outside the mixer, where the power lead enters the main body, between the rectangular lead casing and the socket it enters, there is a small rectangular cutout (top right). Push your screwdriver in around 15mm, and then withdraw the lead housing with it - the screwdriver pushes the latch aside, hence you need to remove both as one! With luck, and a wiggle or two, that should be it.
Kenwood KM300... | Answered on Nov 30, 2016
U have a problem with the rotor.. Need to get it serviced..
Kenwood KM300... | Answered on May 15, 2015
the solution its change the capacitor or triac, normaly problems in models A701 or A901 old motors
regards
kenwoodchefrestore.co.uk
how to videos
Kenwood KM300... | Answered on Feb 02, 2015
Try http://www.torreelectrics.co.uk
Kenwood KM300... | Answered on May 09, 2014
1) remove the front power outlet of the mixer head.
2) look for a notch in either the top edge or the bottom edge of the casting. (hole)
3) Guide Pin on 9xx accessories is at the top of the connecting shaft.
4) if notch and pin point in the same direction, accessory will usually fit (9xx acc's point up and 7xx acc's point down)
Kenwood KM300... | Answered on Jul 31, 2013
The planetary gear housing is filled with grease. Seeing oil come out would indicate that grease has started to or has completely broken down. Take the planetary apart (One nut and a clip), clean out the old grease and liberally repack with a food grade grease something like PTFE Super Lube .
Hi BGR1,
I am also looking for info for info on a Kenwood Chef A700 which seems to have a motor brush problem if you could help I would appriciate it my email address is shanecontrol@aol.com.
Regards Shane
Kenwood KM300... | Answered on Jul 26, 2013
Kenwood KM300 Chef Stand Mixer Logo
166 questions posted
Top Kenwood Food Mixers Experts
Peter GW Fleming
Level 1 Expert
Treefrog15
Treefrog15
Yitz Diss
Level 1 Expert
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
View Most Popular
Kenwood Food Mixers
  • Kenwood Food Mixers
Most Popular Question
high pitched scream when mixing
  • Food Mixers
