Do I have to do something, not mentioned in the manual to get my unit to drain out the hose connection. I know people are stupid, so yes I did open the connection and attached my hose. It has a bit of...
This is usually cased by either a clogged drain hose ro the hose connection and tubing on the unit is clogged. When this happens, water is diverted into the bucket.
First, turn the unit OFF & unplug it.
To unclog the connection and it's interior tubing. Disconnect the hose and using an 18" long plastic Zip Tie appropriately sized Zip Tie, carefully insert the tip into the hose connection and the tubing. Slowly push it in unitl you reach a bend in the tubing. You will need to gingerly work is past this bend, until the Zip Tip bottoms out or you run out of usable Zip Tie. Then slowly pull it out while rotation (twisting) it. This should breakup any clogs. As you reach the tip of the inserted Zip Tie, be prepared as some water may follow. Reconnect the hose to the connection, plug the unit back in, turn it On and lower the humidity extraction level to 35%. Monitor the hose periodically for water flow.
Be sure the hose slopes down and away from the unit and is not longer than 5 feet. As drainage relies entirely on gravity to drain.
NOTE: You may substitute something similar to a plastic Zip Tie. But, no wire coat hangers.
Hope this helped you and thanks for choosing FixYa.
