You can download a manual for almost any equipment by Googling the make and model followed by the word Manual note spelling, then follow the appropriate link(s).
I also have the same problem with my Vivitar DVR 850W camcorder. So, I did research on the subject. I found out, that the battery that is in the camera is the wrong type. The battery is a 3.7V 860 mAh, which is made for a cellphone and doesn't hold a long charge. I found out that the battery is SUPPOSED to be a 3.7v 1000mAh. Quite a difference.
The USB cable does charge the battery if plugged into pc. The red LED will light while charging and go off when the battery is charged. I cannot find any options to buy the software online but the Support email is: [email protected]
According to the manual, your Vivicam 8025 is supplied with a charger, but the battery will also charge via the USB cable when the camera is connected to a computer. Need the manual? You can download/print it here:
Most likely your Vivitar needs a new battery....if you've lost your a/c adapter-you can use a standard USB cable to charge your camera. Plug the smaller end into your Vivitar & the larger end into your turned on PC/laptop & it'll charge the battery.
This camera not charged via PC, you can charge the battery only with wall charger(comes with box).When camera is plugged to PC, you can´t use it as a camera, only as a memory card.You can watch your stuff in PC( PC recognise a camera as a flash memory, no more).
So, this is normal..Charge your camera with wall charger(Full charge Red light not flash!, if light flashed camera is charging) Unplug and use as usually!
