20 Most Recent Vivitar ViviCam X327 Digital Camera Questions & Answers
The reason you get no sound on playback of videos is that this camera has no Microphone. This is one of the most disappointing features of the camera as whilst it has video capability it has no ability to record Audio.
Vivitar have omitted this feature on several models to keep costs down and unfortunately there is nothing you can do about it in terms of adding audio.
If you have a video editing program on your computer you may be able to add a voice over or a soundtrack to the video by using this method but no original audio can be recorded.
Hope this clarifies the issue. Thanks for using FixYa.
Vivitar ViviCam... | Answered on Oct 03, 2019
i also have a Vivitar ViviCam t028 and i just changed the batteries and it wont turn on i was just about to empty the memory card but it wont turn on so i can't i don't know what's wrong with it.
Vivitar ViviCam... | Answered on Nov 28, 2013
Do you really want the Vivitar software?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Vivitar ViviCam... | Answered on Sep 25, 2013
Press the HOME button until the right-pointing triangle appears to indicate you're in Playback mode. Use the right/left button to select the picture to delete. Press the MENU button. Use right/left to select the box with the "x" in it. Use up/down to select the desired option. Press the MENU button. Use right/left to confirm and press MENU again.
Vivitar ViviCam... | Answered on May 28, 2012
This is simply the camera's way of acknowledging that it's connected to a computer.
Vivitar ViviCam... | Answered on Mar 09, 2012
The setup instructions begin on page 19 of the manual. The date and time command is discussed on page 23.
Vivitar ViviCam... | Answered on Mar 02, 2012
The video mode instructions begin on page 27 of the manual.
The playback mode instructions begin on page 30 of the manual.
You can download the manual and the Vivitar Experience software from here.
You don't need the Vivitar software to use your camera. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Press the HOME button until a right-pointing triangle in the upper-left corner of the screen indicates playback mode. Full details are in the "Playback Mode" section beginning on page 30 of the manual.
Put your thumb on the battery door and slide it down a bit until it pops open.
The Date command is in the Setup menu. The Setup section begins on page 19 of the manual. You'll have to skip to page 23 for details on setting the date.
Yes, the X327 records video, though to a memory card and not to a tape.
You can download the Vivitar software here. Click on the "Vivitar Experience Software" link.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as iPhoto or Windows Photo Gallery.
Vivitar ViviCam... | Answered on Dec 28, 2011
You can use ArcSoft ShowBiz which I have tried recently. Their new version ShowBiz 5 is great to add and edit multiple tracks including audio and video ones. You simply drag a music file to the interface and it is added to sound track auto, you drag the edges and the track is cut or spreaded. It's really cool.
Vivitar ViviCam... | Answered on Oct 19, 2011
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ) or Windows Photo Gallery.
Vivitar ViviCam... | Answered on Oct 18, 2011
If you transfer the pics at pc, is the same condition? Black pics in pc? If yes, then isnt the LCD viewer, sound like a malfunctioning CCD-image sensor. Rare, but possible problem with your LCD screenviewer... in both cases (LCD or CCD) this isn't a job that you could solve yourself; this wrong include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
I suggest check THIS LINK for additional details in this previous solutions for an Defective CCD (Charge Coupled Device) and next contact your technical service.
I strongly suggest (taking into consideration the age of your camera) to evaluate the cost of repair versus the cost of a new camera with similar features, before making a final desicion.
Hope this helps
Vivitar ViviCam... | Answered on Oct 12, 2011
Vivitar ViviCam X327 Digital Camera Logo
102 questions posted
Top Vivitar Cameras Experts
Ekse
Damen Wong
Damen Wong
Jeffrey Groves
Jeffrey Groves
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
View Most Popular
ViviCam Vivitar
  • ViviCam Vivitar
Most Popular Question
delete picture from vivitar vivicamx327
  • Cameras
