20 Most Recent
Vivitar DVR 7300x Digital-8 Camcorder Questions & Answers
Battery wont charge
This camera not charged via PC, you can charge the battery only with wall charger(comes with box).When camera is plugged to PC, you can´t use it as a camera, only as a memory card.You can watch your stuff in PC( PC recognise a camera as a flash memory, no more).
So, this is normal..Charge your camera with wall charger(Full charge Red light not flash!, if light flashed camera is charging) Unplug and use as usually!
Regards
Alex
Vivitar 7300X
Blurred pictures
basically, dont use a video camera for still photos. All it does is freeze the frame when you "take the picture". This means any photots will be blurred. I am afraid your xmas pics are likely not repearable wothout a lot of time in photoshop.
Next year, ask for a still camera!
Sorry i cant be of more help
Vititar dvr788hd not on setup cd
You have repeated this query twice, yet given no helpful information. If you could actually state what the problem is, we may be able to assist you, but we are not mind-readers.
How do i turn off the card protect
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
How to charge
I am confused, this camera uses three AA batteries, installed in the bottom of the camera. If you wanted to use rechargeable batteries you would remove them and use a external battery recharger.
