20 Most Recent
Vivitar DVR-550 DV Camcorder Questions & Answers
How to recover erased images from sd card
It is quite possible to recover the photos no matter deleted, formatted, lost or inaccessible from your sd card. All you need to do first is by trying
SD card data recovery software tools. Note: before those files are recovered, never should you attempt to save more data to the card. better stop using it for a moment. Regards.
MY VIVITAR 550 DOES NOT CHARGE AND DOES NOT TURN
Most likely your Vivitar needs a new battery....if you've lost your a/c adapter-you can use a standard USB cable to charge your camera. Plug the smaller end into your Vivitar & the larger end into your turned on PC/laptop & it'll charge the battery.
Dvr550 by Vivitar
I need the driver for the vivitar dvr 550 to install on my computer. Where can I dowload one from?
Dani
Where can i get a charger also what is the price
I found a couple chargers for sale on Amazon by searching "Vivitar DVR-550". The cheapest was 8 pounds sterling, about $12, which was a travel charger capable of using mains outlets in many countries as well as a car cigarette lighter plug.
How do i unlock the
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Converting video to computer
Hi, All you need is the right cable to video card on your computer. The computer will do the rest. (AVI,mpeg4 WMV, AV) These are some of the formats you can use. Most of all make sure the video you make coinsides with Window media. Because you will not be able to watch anything on any devices if you don't. Good luck.
