Konica Minolta bizhub 350 All-In-One Laser Printer Logo
E
ETEL MIGOTT Posted on Jun 30, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
WHAT IS ERROR C-3102 KONICA MINOILTA 550 - Konica Minolta bizhub 350 All-In-One Laser Printer
Thomas Smithbrother
Level 3:
Top Expert:
  • Konica Minolta Master 3,698 Answers
  • Posted on Jun 30, 2014
Thomas Smithbrother
Level 3:
Top Expert:
Answers
3698
Questions
0
Helped
957320
Points
10318
Kmbs.konicaminolta.us/wps/portal/.../support
Konica minolta c550 error code c-3102
1. Turn OFF the main power switch.
2.Turn main power switch ON while pressing the Utility/Counter key. Keep holding it till the T reset appears
3.Touch [Trouble Reset].
4.Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, wait 10 seconds and fire the machine back up, this should reset the service code and with any luck the machine will run!
Solution ID TAUS0800276EN* Solution Usage 1
Description
C-3102 (C3102).
Solution
CAUSE: Fusing roller failure to turn due to a broken Fuser Rotation Sensor Holder.
SOLUTION: Replace Broken Fuser Rotation Sensor Holder (p/n A00J 7323 01).
I have a problem with my konica minolta bizhub c451 giving error Code C 3102
c3102 for Fuser Unit abnormality.
Check Fixing Unit and its Gears , also the drive gear on body.
Reset by Switch On Holding Utility/counter Button for 10 seconds.
Touch TROUBLSHOOT and restart by Power off and on
Reset error code 3102 on Konica Minolta bizhub 6500
drive issue for the fusing motor, get a technician to look at it
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
I am getting error code c-3102 on my Konica minolta bizhub 6500. How can I fix this?
Fusing unit motor or release senor will require a technician to fix.
How do i correct konica minolta 6500 error code 3102
have tech come out to resolve this not easy fusing motor issue and or sensor or both
Konica 3102 error code
well a model number would help
Konica minolta bizhub c450 error code c- d370
I have minolta c450 show error c d370... how can I solve this problem... plz reply me with solution.
2answers
C-OBAO KONICA 3102
Elevator motor ascent/descent drive malfunction.Check and clean the sensors and motors.For reset the error code open and close the front door or set the power switch to OFF/ON.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
