A descendant or the descendants of a person, animal, or plant; offspring. "The progeny of mixed marriages."
As far as a riddle ... perhaps consider one off the "offspring" riddles here:
help solving a riddle
Wendy, RE POST make model # and your complete question, so we at Fixya can answer your question effectively.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
battery is dead (discharge)
the engine will not run with low battery,
cause by 3 things.
1: bad battery
2: bad change system.
3: phantom drains.
a volt meter for $7.88 at walfart solves this riddle, ask
bad ground to horn
bad relAY TO HORn
bad wires to all horn circuits
bad horn button.
bad clockspring contacts in steering hub.
no matter way we use a voltmeter to solve this, riddle in 5min work.
i always start in the middle (training) to make 1/2 the possible go byebye in 1 simple test.
ask.
if the relay dont pull in at failure, bingo. 1/2 problem solved.
is this clear?
that would say the relay is bad, or power to it lost
or the horn button path is dead.
causing 2 more simple tests.
ask. if you own a $10 meter... volt meter. of any kind ever made.
watch this video and you will be much more better at solving riddles. This video is the video that got me really good at solving but ovcourse it will only make you good if you speak some different languages but all i did is i put into English converter if you know what that is.
