Tablets & eReaders Logo
A
Anonymous Posted on Jun 29, 2014
Tablet touch is super delayed.10-30 seconds may pass from touch to highlight action
So slow loading, turning on, anything and everything delayed
2answers
Apps not responding an running very slow
Everything is suddenly slow or is not responding. - Windows 8 Forums
www.eightforums.com > ... > Performance & Maintenance
Jun 24, 2014 - 10 posts - ‎2 authors
... year old and it started to load everything really slowly or is not responding for ... of memory to run Windows 8 efficiently so that isn't the problem. ... (It's not always showing, that the application is not responding, when it froze).
Solved: system is extremely slow and everything is "not responding ...
forums.techguy.org > Forums > Operating Systems > Windows 7
Sep 13, 2013 - Solved: system is extremely slow and everything is "not responding" ... Only after several minutes do the programs become responsive again, but once I try ... If using Vista or Win 7 - right click the icon - run as Administrator
iMac very slow, apps not responding, wheel turning ' Apple Support ...
discussions.apple.com > Support > Apple Support Communities
Apple Inc.Sep 28, 2012 - iMac very slow, apps not responding, wheel turning ... (Expect it to take longer to start this way because it runs a directory check first.). Mac runs super slow and apps not responding
Apr 23, 2015
running very slow and apps not responding
Sep 20, 2013
Macbook running slow and all applications stop responding - Apple ...
Jul 29, 2012
Running slow, Not responding
Oct 10, 2011
More results from discussions.apple.com
System is frozen. Wont shut down or go to start screen.
Here are two things to try:
I- Using the Power button:
1 Press and hold the Power button for at least 4 seconds.
2 Swipe-down the shutdown confirmation screen to the bottom
edge of the display to turn off the tablet.
Using Charms:
1 Swipe-in from the right edge of the display to access Charms.
2 Touch Settings
Turning Off the Screen
Press the Power button to turn off the screen.
Using Charms:
2 Touch Settings
NOTE: If your tablet is in a standby state (tablet is on, but screen is off), press the Power button or Windows button once to turn on the screen.
12
Setting Up Your Tablet
? Power
? Shut down to turn off the tablet.
II- Unplug the battery, wait 30 seconds, then install the battery again.
I have a dragon touch tablet model A93 and touch screen is not working. I can't tap or press anything
Can you turn it off? If so turn it off then hold the volume button down and the on button at the same time for about 10 seconds. Factory reset will be available to you then.
Hope this helps
John
I have forgotten my login password for my lenovo tablet ce0700
If you really can't remember the login/pass then you can do a factory reset.
** Your tablet will be back to the original settings, you'll have to redo the setup and reinstall all your applications.
  1. Turn off your Tablet.
  2. Hold the Volume up + Power Button.
  3. Press it for 5-8 seconds
  4. Android robot will appear
  5. Navigate in the menu by using volume keys.
  6. Highlight the option named "Reset device" or "Wipe Data" and select it by pressing power button.
  7. Confirm yes to "Delete all users Data"
  8. It will start formatting your device
2answers
Stuck on loading, won't go pass loading even after resetting
First thing to do is try a soft reset. Hold volume up button and whilst holding it, hold power on button till it boots up. Really hope this works for you.
7 INCH RCA TABLET SCREEN TURNED DOWN CANT SEE ANYTHING TO BRIGHTEN
Hello I have Rica table. It turns on and everything but i can't see anything it has sound I can still touch the screen but I can't see anything when I touch it pleasenhelp
4helpful
I have an archos 28 internet tablet and i forgot my pass pattern how do i by pass it
From the Archos User's Manual.
- Press and hold the power button until the ARCHOS banner is displayed and then release it.
- Press the power button twice (like a mouse double-click) while the banner is still displaying.
- A white Recovery screen should appear within a couple of seconds.
- To move from one option to another, press the power button. To select the highlighted item, hold down on the power button.
You'll want to select the Format System option.
P1510D Lifebook slug
Try doing a system defragmentation, your programs may be so fragmented that loading time is impaired. Also clean up the hard drive by doing a Disk cleanup. Both of these tools are in the popup menu on the start page under the Accessories menu and then the System Tools menu.
Top Proscan Tablets & eReaders Experts
 Mikey
Mikey
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you a Proscan Tablet and eReader Expert? Answer questions, earn points and help others
