20 Most Recent
Fujitsu LIFEBOOK P1510D Tablet PC Questions & Answers
P1510D Lifebook slug
Try doing a system defragmentation, your programs may be so fragmented that loading time is impaired. Also clean up the hard drive by doing a Disk cleanup. Both of these tools are in the popup menu on the start page under the Accessories menu and then the System Tools menu.
Forgot windows login password
Hi, there. This all-in-one
password recovery software will surely help you out. It is capable of
resetting forgotten Windows Administrator login password, and recovering lost password for multiple web browsers, mail clients, FTP clients, chat messengers etc. Next time better make a password recovery CD and put it in safe place. best regards.
I forgot my password on my log in screen what do i
Hey, I also got locked out of my computer several days ago. I tried several free software. It took me two days and got quite messy. Unfortunately none of them work for me. Finally I made it work with Windows Password Recovery Tool 3.0 . The good news is that it works. The bad news is it is not free. You can try
Windows Password Recovery Tool 3.0 . It works for me.
Check this out:http://www.windowspasswordsrecovery.com/
How do i use recovery
When you boot your computer, start up your BIOS, then under the boot menu, make sure USB is listed as the 1st option.
To log into your BIOS, press the "Boot Option" key. It might be F1, F2 or Delete
Blue screen
Startup PC, press F8 at instant of turn on... choose Safe Mode. when you are asked if you want safe desktop or system restore choose restore, when you get to the restore menu, choose a date BEFORE you had problems there may only be one or two to choose from. just follow the instructions and you should be back to working with all that behind you.
Set up did not find any hard disk drivers installed on computer
Your notebook has SATA hdd. Got into the bios (keep pressing F2 key on startup) then in the bios screen find HDD and press enter. Select IDE mode. Press f10 to save changes and exit. When this is done install XP.
Alternatively connect external usb floppy drive and unzip sata drivers into that. When booting from xp cd press f6 to load drivers.Follow onscreen instructions to load drivers and continue xp installation.
Please let me know if issue not solved for futher ts steps.
thanx
Lifebook P1510D network connection
i had the same problem, i had to install the updates on the "drivers and applications restore cd". however that didnt work. so i had to download the 1.030 driver from the fujitsu web site. this worked. but when i tried to calibrate the tablet i was not able to get it aligned.
there used to be 2 different programs for updating the tablet, but now i cannot find the other one.
The clock of notebook delay
Try to check the geographical location setting and time zone. It has to be set to the right location and time zone. Once your computer connects to the internet, it will try to sync with the right time in the internet. If that will not work, then it is with the CMOS battery. It will have to be replaced.
Notbook is crashing
Hi.
This could be as simple as a loose or poor connection somewhere. There are a couple of things that I would look at. Firstly, try another ac mains adaptor incase the power lead is intermittent. Next you could look at the power socket on the back of the laptop. These can play up and sometimes are responsible for poor connections. The above will be made worse if you have removed the battery or if the battery is old or poor. Put a decent battery in and keep it charged even if you are using a power adaptor. If there are breaks in power the battery will act as a reservoir and prevent dropouts.
You say that it crashes when you move it, is it ok when you leave on a table and operate it?
The only other thing I can think of is that there could be a loose connection inside the unit. I would check out the connection ribbons before pulling out chipsets or motherboards. Good luck..
Numbers typed with letters
What Operating system have you got?
Try resetting your regional settings in Control Panel.
Have you dropped it accidently?
I deleted a dll file for my omnipass
Try booting up into safemode.
Reboot your pc.
Keep pressing F8 before you see the windows logo.
If you did it right, you should come to a screen where you can select Safemode.
If that doesn't work call Fujitsu support and ask for a recovery disk.
