Home Logo
A
Anonymous Posted on Jun 27, 2014
1-1/2 clst spud fric ring - Danco Home
What fuse controls dashboard gauges on 2002 jeep liberty
It should be labeled Inst. Clst. or something like that on the lid.
My eljer tank cracked and I need to install a new tank. How do I just install a new tank? The bowl is fine. Companies are trying to charge me about $300 to do this and I do not have the money. Please...
Let's assume you can buy the tank.
Installation of tank is simple.
If you can buy the eljer tank, you can buy whole new toilet with bowl and tank from home center.
We'll walk through instructions for both options.
1) How to replace tank on existing bowl.
-Tank is attached from underneath with two nuts.
-Turn off water, and hold flush valve down to drain tank
-Water connection is one nut. Follow supply line up to where it connects to tank. Loosen the nut that is around supply line just underneath tank. Pull nut downward and notice a black rubber washer that is probably stuck inside nut, or is stuck at bottom of tank. Make a note of where that nut is because it seals the water line to tank.
-You might also have a flex connector instead of supply tube. In that case, just unscrew flex connect from bottom of flush valve.
-Look beneath the tank and there are two nuts that hold tank to bowl.
-Take off these two nuts. A ratchet and socket is best tool, but you can use crescent wrench. -Notice these nuts are not exceptionally tight, but they are firm.
-Straddle the bowl and hold tank with two hands and lift up. Tank will come right up.
-Notice that on bottom of the tank: there are 2 bolts sticking out and there is a spongy rubber washer. This is the spud washer. Your new tank will have new washer. This washer seals tank to bowl so water doesn't leak when you flush.
-Notice round opening where flush water flows into bowl. Spud washer seals this hole. If you have experienced slow flushing, or if you have hard water, pour several cupfuls of CLR Calcium Lime Rust into the hole. CLR is sold at Home Depot by the gallon for $10.
-Open box to new tank. Find spud washer and fix it to bottom of new tank.
-Now a new tank is slippery, I want you to set boxes on floor nearby so if tank starts slipping, aim toward a box instead of hard tile floor.
-New tank comes with 2 new bolts, with nuts. Look at instruction sheet and see exactly how they want you to connect bolts to tank. Look carefully where they want you to put washers. These washer seal the tank when you tighten bolts.
-Now your spud washer is in place, the bolts are attached to tank and are sticking out of bottom of tank.
-Straddle bowl and lower new tank into place. Make sure spud washer lines up. Bolts line up. And flush valve lines up with supply tube. It's that easy.
-Tighten the nuts. Remember, not too tight. Toilet is not steel. And you can tighten more if there is seeping water.
-Now tank is in place. Raise nut and washer that are on supply tube and tighten nut onto bottom of flush valve. This nut is fairly tight. You might want to buy a new washer.
-If you have a flex line for the water supply, then just connect the flex line.
-Turn water ON a little bit at a time to avoid gusher if something is not correct.
-Use paper towels to check for dripping or seepage beneath tank. Tighten nuts appropriately to end seepage.
-Flush toilet and look for seepage around spud washer.
-You're done.
2) How to install new toilet.
-Remove old tank as shown above.
-Bowl is held to floor with two nuts.
-Ideal world those two nuts come right off and you lift bowl up off the floor.
-Real world, those nuts are rusted and you have to drill through side of the nut and bolt to break it off.
-Lift bowl up.
-Have cardboard ready next to toilet so you can set bowl on something. Or set it in bathtub.
-Bowl will be damp and wax ring is on bottom of bowl and will mess up the floor.
-Notice how the toilet bolts are set in the floor flange. Take photo if needed so you can put it back. It's real simple, but if you have never done this, a photo might help.
-Take putty knife and scrape wax ring off of floor flange. You want it smooth, but you don't clean it.
-New toilet comes with wax ring and bolts, but you might have to buy these at hardware store. Get wax right with gasket. The boxes are marked. Buy two of them.
-Set wax ring in center of floor flange. Gasket goes downward. Rounded side of wax ring goes up.
-Set new toilet bolts into floor flange. Keep bolts straight up using wax from the old wax ring, or from 2nd wax right you purchased.
-Keep bolts straight across from each other.
-Time to set the toilet.
-Stand in front of bowl and grab on either side at point where seat connects.
-Here's the fun part.
-Bowl has to go straight down onto wax ring so you have to be strong enough to hold tank level while aligning tank with bolts, without knocking the bolts down. Like a carnival game.
-Straddle walk toilet while holding it up high enough so it will not knock over the bolts.
-Lower bowl into place going straight down using bolts as guide. Lower a little bit and check one side for alignment and then check other side until bowl is going down and bolts fit through the holes.
-If bolt falls over or gets pushed away, straddle walk toilet back and set bolt straight up again.
-Once bowl is aligned, keep pushing straight down on bowl, and finally use your weight to push bowl to floor. Be careful to keep bowl perpendicular to wall so tank will sit straight.
-Attach bowl to floor with nuts and washers.
-Install tank as shown above.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on toilet or any do-it-yourself project.
3helpful
My toilet only leaks when flushed. It seems to be coming from the connection at the tank. The tank is not cracked and a new hose from tank to shut off valve has been installed. The toilet is only 4 years...
If you have 2-part toilet, then tank is attached to bowl with 2 bolts.
Look inside tank and you can see bolts with rubber washers located on either side of flush valve.
The 2 bolts hold tank and bowl together and between tank and bowl is a washer called the spud washer.
So spud washer could be leaking ... or 2 bolts could be leaking.
1) If bolts are leaking, there is usually dripping all the time, and drips are visible on bottoms of bolts
If spud washer is leaking, then tank could leak only when tank is flushed.
2) First thing to try is tightening nuts on the 2 bolts. Nuts may be loose. Tighten nuts a few turns, and check if toilet still leaks.
3) To fix a spud washer, you usually need a new generic one from hardware store.
Newer tanks with 1.6 gallon flush have special sized spud washer.
geno_3245_105.jpgTank is upside down and spud washer is fit over flush valve
If you cannot find new spud washer, re-use old one and smear retorseal on it during re-assembly to make sure it seals. Rectoseal is good for many home plumbing repairs. More about that in a moment.
4) To take apart tank: Disconnect supply line to tank. Empty water out of tank. Remove nuts from bolts. Lift tank off. Wash out tank with hose. Make sure there is no sand or sediment left in bottom that might clog up flush holes located inside bowl after tank is re-assembled.
5) Remove old spud washer, and put new one on. Do a google-image search for 'spud washer' if you need more photos. New spud washer fits over flush valve. That's it. And then reassemble tank.
If you want to apply rectorseal to washer, put washer on as shown in photo above. Then smear-or-gawm rectorseal over area of washer that sits on bowl. Rectorseal will make sure there is no more leaking.
'move fric.lever' message. Kindly please explain. Thanks
It is telling you to move the friction lever.
The friction bar holds the paper against the platen roller, it must be in the closed position to advance the paper.
The lever should be to one side of the roller.
The locking nut on my micrometer does not lock anymore, can i fix this?
yes. Just remove the screw in the lock, lift the lock arm off its shaft, and reposition at different angle. (put to lock, take off without turning, and set back on at unlocked position...may ned adjusting)
good luck
2answers
Where is the cigarette lighter fuse located?
i think its the #7 fuse in engine fuse compartment on buick
hope it works
rate it
3helpful
3answers
How do you get the urnial spud assembly to seat to the top of the urnial?
you have to get a wrench and either hold the threads on the spud and turn the tightening nut or get a wrench inside the pipe and catch it on the notches in the middle of the pipe and it should tighten down and walla! make sure you have the right size for it as well if it's alittle off it wont seat
Thimble on 0"-1" micrometer is tight.
spray some silicone into the thread areaand open and close it a few times.
Water seeping through drain spud area of Aprilaire 600 model.
Clean it and dry it thoughly. Apply a small amount of 100 % silcone caulking with you finger. Seal it on both sides. Allow it to dry thoughly before it gets wet or it will leak.
Top Danco Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Danco Home Expert? Answer questions, earn points and help others
