First remedy fault. E32 fault code usually mean problem with water level in drum respectively to pressure switch.
Incorrect calibration of electronic pressure switch
(electronic pressure switch level different from
0-66mm after initial calibration drain and anti-boiling
pressure switch on "empty")
Could be: Tap closed or mains pressure insufficient; solenoid
valve;hydraulic circuit of pressure switches; pressure
switches; wiring between pressure switch and printig circuit board; main PCB
Dado
