Toshiba Satellite A135 Notebook Logo
A
Anonymous Posted on Jun 24, 2014
Default bios password toshiba l305-35909 - Toshiba Satellite A135 Notebook
Chris Neary
Level 3:
Master:
  • Toshiba Master 369 Answers
  • Posted on Mar 12, 2015
Chris Neary
Toshiba Master
Level 3:
Master:
Answers
369
Questions
0
Helped
117003
Points
3250
Most Toshiba laptops and some desktop systems will bypass the BIOS password if the left shift key is held down during boot
5 Related Answers
Anonymous
  • Posted on May 24, 2008
SOURCE: default bios password toshiba satellite a135-s2276
I have a Satellite A135-S2356 that had the same problem. I tried the solution from PCTServices above and it worked great.
"Power unit off. Disconnect AC power. Remove battery. Remove the memory cover screw, memory cover and the memory modules. Peel back mylar from JOPEN1 solder pad. Short JOPEN1 solder pads for 30 seconds. Replace mylar. Replace memory modules. Replace battery. Power up unit. If all is well, replace memory cover and screw."
Just short the two little solder pads and it worked great! I thought I would have to send it back to the manufacture but I am back in buisness. Thanks for the help.
Bryan
mike block
  • 16 Answers
  • Posted on May 29, 2008
what you need to do is pull both the laptop battery as well as the cmos battery. in some instances, the battery can be pulled, but on other models, i have seen the battery as an actual physical part on the motherboard or somewhere where it is not easily accessible, in which case you need to clear the cmos by using a jumper on the motherboard, since it is a laptop, they are all different. you may need to see if you can locate a copy of the motherboards schematics and go from there.
myob247
Georgia B
  • 1342 Answers
  • Posted on Jun 03, 2008
Some Toshiba's can be convinced to bypass the startup BIOS password if you hold down the <LEFT-SHIFT> key while booting the system.
Anonymous
  • 46 Answers
  • Posted on Aug 10, 2008
Did you get this from another person or business?
Either way there's a way to get rid of it.
Let me know
comier957
Anonymous
  • 94 Answers
  • Posted on Aug 18, 2008
SOURCE: Need a password...
Found these instructions on another website...
Hope this helps
Regards
Default bios password toshiba l305-s5909
Most Toshiba laptops and some desktop systems will bypass the BIOS password if the left shift key is held down during boot.
Remove bios password
If it is just a BIOS password you can try as many times as you want. If it is a HARD DRIVE password, do not even try a password or it will lose all of the hard drive's information.
Unfortunately if none of the following passwords work, you may have to take the laptop apart and take out the jumper next to the CMOS battery (it looks like a watch battery).....wait 10 minutes then put it back in. This will reset the bios password.
First, try the word "Toshiba". Sometimes manufactures leave a default bios password for servicing. Try the word "toshiba" upper-case and lower-case in every which way.
If you know the BIOS manufacturer you might try one of these:
AMI BIOS Backdoor Passwords:
  • A.M.I.
  • AAAMMMII
  • AMI
  • AMI?SW
  • AMI_SW
  • BIOS
  • CONDO
  • HEWITT RAND
  • LKWPETER
  • MI
  • Oder
  • PASSWORD
Award BIOS Backdoor Passwords:
    • (eight spaces)
    • 01322222
    • 589589
    • 589721
    • 595595
    • 598598
    • ALFAROME
    • ALLY
    • ALLy
    • aLLY
    • aLLy
    • aPAf
    • award
    • AWARD PW
    • AWARD SW
    • AWARD?SW
    • AWARD_PW
    • AWARD_SW
    • AWKWARD
    • awkward
    • IOSTAR
    • CONCAT
    • CONDO
    • Condo
    • condo
    • d8on
    • djonet
    • HLT
    • J256
    • J262
    • j262
    • j322
    • j332
    • J64
    • KDD
    • LKWPETER
    • Lkwpeter
    • PINT
    • pint
    • SER
    • SKY_FOXSYXZ
    • SKY_FOX
    • syxz
    • SYXZ
    • TTPTHA
    • ZAAAADA
    • ZAAADA
    • ZBAAACA
    • ZJAAADC
Phoenix Backdoor BIOS Passwords:
  • BIOS
  • CMOS
  • phoenix
  • PHOENIX
Bios password default toshiba satellite
If it has been set, to remove it needs the internal battery removing, or an internal link connected. After battery or link done, for 30secs or less, bios will be reset to defaults
How do I remove my toshiba bios password? When I turn on my computer it instantly asks me for my password (Bios). I am unable to even get into my windows
The way around a lost/forgotten BIOS password is to reset the password to the default BIOS password, which is: no password at all. A BIOS will accept a password, but will not set one by default.
The way to reset your BIOS password, since it is not stored in flash memory, but is stored in battery-backed ROM, is to (utilizing proper static control techniques) remove the CMOS motherboard battery (a button cell), leave it out of the computer for a few minutes, then re-install the battery, and reboot the system. This will remove the BIOS password (and reset all BIOS parameters to their default, including the BIOS password), and send you into MSWindows, where you'll be prompted for Windows passwords to each of the password-protected accounts on the computer.
In brief, your anti-static technique of choice is an anti-static strap clipped (via simple alligator clip) to the frame (ground) of the system. In a tower computer, ground would be the frame, whereas in your Toshiba laptop, a number of grounds are available, such as a screw securing an output port, or other means of grounding as specified in your laptop's service manual.
Here's a link to a how-to for replacement of the CMOS battery in a Toshiba L305-S5895 laptop.
http://www.ehow.com/how_8198282_replace-battery-toshiba-laptop-l305s5895.html
My bios password is unknown and i can not access the actual settings. i can however boot into windows.
Normally, Toshiba may have a default password such as "toshiba", try that first.
If not successful, then power down the laptop, remove the battery for about 30-45 minutes, then power back and go into bios, the password should be gone.
It is important to remember that with this method, the bios goes back to factory defaults and the time and date may have to be reset.
It neither do not remove the password, then the bios has it's own battery and would have to be accessed and removed to clear out the password. I do not recommend this option unless you
are knowledgable about disassembling the portion on the unit to get to the battery.
Good Luck
Remove toshiba password from bios satellite 3000-x4
The Basic Input/Output System (BIOS) password is not set by default on Toshiba laptops. When set, the BIOS password must be entered every time you turn on your Toshiba or wake your system from Standby mode. If you forget the password, you cannot boot your system. Prevent having to enter a password or the results of forgetting the password by removing the BIOS password from your Toshiba laptop. Other types of passwords can be set, such as a Windows password, to prevent unauthorized access to your machine.
1. Turn off your Toshiba laptop.
2. Wait 30 seconds and turn your laptop back on.
3. Press "F2" repeatedly as soon your Toshiba laptop begins booting until the BIOS menu screen appears.
4. Enter your existing BIOS password and press "Enter."
5. Press "F2" again to enter the BIOS, if prompted.
6. Use your arrow keys to select the "Security" tab in the BIOS menu.
7. Use the arrow keys to select "Set User Password."
8. Press either "F5" or "F6," depending on your Toshiba laptop model, to open the Password section.
9. Enter the current password into the "Old Password" prompt and press "Enter."
10. Press "Enter" when the "New Password" prompt appears. Do not enter any text in this box.
11. Press "Enter" again to confirm the new password.
12. Press "F10" to save your changes and exit.
I hope you find it very helpful. Best regards.
Please help me !! i need Toshiba A135-S2276 PW cmos default .
The BIOS password is removed by the BIOS configuration, you need the BIOS password to get into the BIOS configuration.But if you do not have the BIOS password then you need to construct this dongle device.
TOSHIBA BIOS PASSWORD DONGLE
You can build a dongle that plugs into the printer port.Purchase a 25 pin male D sub connector and solder insulated wires to the various pins as listed below. The pins are numbered on the connector
http://www.tilman.de/sonstiges/toshiba/dongle1.jpg this is a picture of the finished dongle
Wire the pins as follows :-1-5-10, 2-11, 3-17, 4-12, 6-16, 7-13, 8-14, 9-15
Plug the finished dongle in the printer port and power up the laptop. The password will be reset, go into the BIOS configuration to check the BIOS password, you may have to disable the BIOS password.
2answers
Bios password needed!
plz check the website for bios passwords
http://www.tech-faq.com/reset-bios-password.shtml
1helpful
2answers
Default bios password toshiba satellite a135-s2276
2answers
Toshiba P105 S6104
A lot of the computers come with the factory default password "admin". You might try this.
If this is a bios level password, you may have to reset the bios on the motherboard. I would recommend you contact customer support.
If this is a Windows password you can get fixes on the Microsoft website.
Hope this helps.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
