Replaced controller motor will not start no fault codes
SOURCE: find board for maax bubble-tub
You will probably have to go to the manufacture website to find a dealer in your area that you can purchase one from. Also, you can check online as well for specific parts for your tub. If often just google the brand and model number and start clicking on links to find what I want or need. Good luck to you!
SOURCE: Hydro maax wirlpool bathtub Model # J6061 Pump will start
Can either be a bad motor or if the motor has a capacitor, it needs to be replaced. I would call a service professional to come out.
SOURCE: maax infinity hot tub error code clfl dont have
Found at http://www.maaxcollection.com/Produits/ProductInfo.aspx?cat=1&fmly=1315&mdl=1851&sp=2%3b5%3b215
Click on "Installation Guides" under the "Downloads" blue highlighted box. Then download the "Whirlpool Installation and User Guide".
Quite sparse on error codes, but p19-23 have some.
...soon to be owner/user Maax Infinity bahtubber
SOURCE: Maax tub LM65519 control panel has broken lines running through
Broken lines where? are you referring to broken water lines or the actual control line?
rod
us parts center
