VPR has a semi-sealed tank that keeps +1 pot of water heated and ready to brew. Pouring in a full pot of cold water will fill the top tray and allow a slow trickle of cold water into the top which forces hot water to over flow into the brew basket. This continues until all the cold water drains into the heater tank. So the brew is matched volume per volume. UNLESS the tank was empty or not filled prior to brewing. Follow the brewing instructions from Bunn (on line for *FREE* download at Bunn.com)
* If it leaks (from the bottom) only when you pour in water. Then your pouring it too fast and over flowing the fill tray. slowdown, watch the level in the tray. do not fill past the lid.
* If it leaks just sitting (not brewing) then there is a hole in the tank. Call for service.
* If it leaks after filling the tray half way. then the top of the tank has a leak, loose, cracked, or missing gasket. There is quite a few gaskets on the lid. Call for service.
* Final; Leaks are always bad around electrical equip. Best to unplug and call for service to be safe.
Aloha, ukeboy57
SOURCE: my bunn coffee maker leaks
You need to replace the washer kit inside the top of the maker. Remove the 3 screws that fasten the top and lift it off. You will see the rocker leaver that allows the water to flow into the tank. At the point where the rocker stops the water there is a series of washers that degrade from the heat over time and allows the leak. The washers are very easy to replace. The problem is finding the washer kit. I found it at: www.buyitnow64.com for $3.95 plus shipping (FedEx is only $9.98). I bought 2 (one for backup) kits.The original washers lasted almost 6 years. I had repaired this problem before with a washer from my shop but it broke down rather quickly from the direct heat from the tank. This washer kit is a Bunn washer kit that is supposed to fit all Bunn machines both residential and commercial.
Hope this helps. It took me 2 hours on line to find the washers!
SOURCE: Water supply for Bunn coffee maker
open the cover on the brewer- depending on your model, it could be the front or the back cover. look for a brew timer dial. turn this up slowly, running a brew each time to see if you now have a full pot
SOURCE: my bunn coffee maker leaks, were can I get parts?
You can call Bunn Home division in Springfield, IL at (800) 352-2866. They have a kits which you can try at no charge. If that does not work, they will replace your coffee maker at discounted price provide you send the old one in. On the bottom of your coffee maker there is a modle number which they need on a white tag. .Hope this helps
SOURCE: I have a bunn coffee maker the NHBX is the # it is
Please give Customer Service a call with the model and date code. If the machine is 3 years old or less, it will be replaced with a new machine. If it is older than 3 years, it can be exchanged for a reduced price.
