My d90has only a blinking "clock" sign in the top LCD panel and the battery level sign. Nothing else. Won't reset and awon't react. Any advise?
SOURCE: i broke my nikon d90 battery door. searching
Dear i have a link better than for you.
in this link you could see the manual of your nikon battery door.
https://www.paypal.com/us/cgi-bin/webscr?cmd=_flow&SESSION=a7JqcrKsQQGVfav71QTTIc0JLuta7te9SDOjhDCCaISkL1Kh6V2nBJcZMaK&dispatch=50a222a57771920b6a3d7b606239e4d529b525e0b7e69bf0224adecfb0124e9b5eb2336391e7cbed125f6c5bdaf8a1cdeb9b6b1b7e42e65e
SOURCE: Nikon D50 - clock and battery icons blinking
Hi
I had the same problem and rectified it by going to Nikons website , follow this link for the answer:
http://nikoneurope-en.custhelp.com/app/answers/detail/a_id/10601/p/19%2C244/c/241/kw/Clock/r_id/127673
SOURCE: got my Nikon d90 for
This is a common problem with this camera/lens conbo. I "solved" it by removing the lens, then reinstalling it - but hold the lens release button down, and rotate the lens a nuber of times (in the camera body) before releasing the button. It appears that the issue is poor electrical contact between the lens and camera body. If there is a poor contact, the camera will not know if thereis a focus and will lock the shutter release. With this poos contact, the camera will only fucntion in manual mode
Hope that this helps
SOURCE: Nikon D90 Memory Card Access Blinking
It's a deadly common problem of D90. Fixation:Simply go to the DSLR repair shop and ask them to change the power circuit board of the camera. Will take $60-70 if the board available. Reason of issue:The power control IC get short and feedback the battery power to the battery causing the draining out and other problem like the top LCD back lamp turned ON after turning on the camera. Careful:To avoid this issue in future, after full charge of the battery, do not put it in the camera right then. Wait for the battery to cool down for 5-10 min and then put it in. With the full charge, the battery hold high ampere for a short time. It could damage the power distributor IC suddenly if you put it in the camera right after a full charge. Best, Leo>>from personal experience<<
