20 Most Recent Nikon D90 Body Only Digital Camera Questions & Answers
2answers
My computer stopped recognizing my
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
2/11/2015 5:49:46 AM • Nikon D90 Body... • Answered on Feb 11, 2015
Nikon D90, I take the pictures but blank screen comes on to display screen on quick review and same on the Play mode as well. It is a new camera
Don't try to fix it yourself. If it is new, it is still under Nikon's one year warranty. Contact Nikon at 1-800-NIKON-US (1-800-645-6687) 9AM-8PM EST, Monday to Friday.
10/3/2014 1:44:05 AM • Nikon D90 Body... • Answered on Oct 03, 2014
Control panel light always open
It may be a setting. Push the 'Menu' button. Scroll to 'Custom Menu Settings.' Scroll to 'D Shooting/display.' Scroll down to item 'f1 (light bulb icon) Switch.' Change the setting from 'LCD backlighting' to 'Both.'
10/2/2014 4:37:11 AM • Nikon D90 Body... • Answered on Oct 02, 2014
Memory card is alwasy flashing in D90
This indicates a problem with the memory card. It may mean the card is corrupted and will have to be replaced. It's also possible that you may be able to fix it by formatting it. You can format the card either through the camera menu or by simultaneously pressing the little trash can icon button at the top left on the back of the camera and the metering button on the top right next to the off/on switch. Both are marked with red and show "format" in tiny letters. Press both buttons for 2 seconds. A flashing "FOR" will appear in the display. When it stops flashing, the card is formatted. If there's a problem with the card, there may be some sort of error indication. If the card can't be formatted, it is corrupt and needs to be replaced. If you have pictures on the card, they will be lost when you format it. You might want to try to download any pictures from the card to your computer before you format it, but if the card is corrupt you may not be able to do that.
9/9/2014 10:55:17 PM • Nikon D90 Body... • Answered on Sep 09, 2014
What is error r02 on my Nikon D90?
r02 error have you tryed to fomate and remove Sd card remove lens and replace remove battery and replace you should be ok
8/9/2014 8:35:47 PM • Nikon D90 Body... • Answered on Aug 09, 2014
D90 won't work. Blinking Clock in top LCD panel.
First, turn the camera off and then remove and reinstall the battery. Turn the camera back on. If the clock and battery icons still appear, try resetting the clock. If this doesn't work, contact Nikon technical support at www.nikon.com and see what they have to say. It may require a repair but determine if the camera is still under warranty. If so, Nikon may repair it at no charge.
7/14/2014 6:27:54 PM • Nikon D90 Body... • Answered on Jul 14, 2014
2answers
Turn off focus assist beam on Nikon
Custom Setting Menu A, autofocus, setting A3 "Built-in AF-assist illuminator".
174 in my D90 manual.
"Choose whether the built-in AF-assist illuminator lights to assist the focus operation when lighting is poor"
6/6/2013 6:38:05 PM • Nikon D90 Body... • Answered on Jun 06, 2013
Image does not appear on media card when picture is taken
Check to make sure that the little sliding part on the side is not set on protect, so that you can't write to the card. AIf the card is OK, then the card holder on the circuit may be damaged. Check it with a strong flashlight for small broken plastic bits from a card that is keeping th e switch closed. If the switch is bent, you can try and straighten it with a small screwdriver blade.Remove the batter before you try any of this.
3/21/2013 12:36:58 AM • Nikon D90 Body... • Answered on Mar 21, 2013
0answers
How to change japanese to english language in a nikon d90
Press the MENU button. Press cursor-left, then cursor-up/down to select the wrench icon. Press cursor-right. Use cursor-up/down to select the item that says "Language" in the current language and in English. Press cursor-right. Use cursor-up/down to select "English" and press the OK button. Press MENU to exit the menu.
4/3/2012 6:18:17 PM • Nikon D90 Body... • Answered on Apr 03, 2012
Is r13 an error message? If so, what is the error?
No. It's merely telling you how many more pictures you can take in the current burst before the buffer fills.
7/9/2011 12:10:19 AM • Nikon D90 Body... • Answered on Jul 09, 2011
2answers
How can i tell if my nikon is a fake?
8016387 nikon d300s could you chek this please fake or not?
3/25/2011 8:20:05 AM • Nikon D90 Body... • Answered on Mar 25, 2011
Hello, how to check if
Personally, I never seen or heard of a fake DSLR camera before because it would cost a lot to make and work just as good as the real thing.
There are a difference in where they are manufactured, for example grey market and domestic market.
Grey Market camera gears are usually a little bit more affordable because it is manufactured somewhere else other than in your own country (US) and carry oversea warranty. The problem is the warranty will not be honor from Nikon USA because it is not manufacture from a US manufacturer or distributor.
SO when you shop, make sure that you are buying from a US distributor and not from a Grey market vendor. Some sites like B & H photo has an option for you to choose if warranty to you is not an issue.
I hope this helps.
3/2/2011 11:59:30 PM • Nikon D90 Body... • Answered on Mar 02, 2011
I recently purchased a nikon
Try contact Nikonusa.com support.
2/16/2011 2:33:25 PM • Nikon D90 Body... • Answered on Feb 16, 2011
I would like to buy a Nikoni d90 camera on
Craigslist advises that you only buy from local sellers, it is a good idea. Find one you like and ask the seller to meet you in a public place so you can inspect the camera. You do not have to pay for the camera if they don't show up or it is not a good camera. I use Craigslist very often and it is very reliable, but, buy locally.
1/16/2011 4:38:27 PM • Nikon D90 Body... • Answered on Jan 16, 2011
Nikon D90 Body Only Digital Camera Logo
Popular Tags
44 questions posted
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
D Nikon
  • D Nikon
Most Popular Question
error r02 nikon d90
  • Cameras
