Boss Rc 50 Logo
s
suchyb Posted on Jun 11, 2014
How do i get more internal memory in Boss RC50?
Hi, I uses the Boss RC50 more as a sequencer for songs than a looper. I pre record drums etc in my studio then assign them to the 3 pedals - usually 1=verse 2= chorus 3= bridge. This has worked really well for me and is a great way to have the full "band" sound when the band can't make it and its just me. My problem is the internal memory is now full in the pedal. I have gone through and trimmed the fat off of some of my loops but it is futile - also cuz i got more songs i want to put on there. Currently i got about 28 songs on there so at least i can do a couple sets or one good 1.5 hr show. I have considered storing different sets in folders and then dragging them into the pedal, but i believe the names and settings don't transfer but I'm not positive on this. I have heard the bossrc300 has more space, but don't have the coin and haven't tried it yet.
5 Related Answers
Anonymous
  • Posted on Feb 13, 2009
SOURCE: The Distortion Pedal has no effect on the sound.
i got d same problm. i fixed it myself.. check all the op amp ic's if they're all gud. if youre not sure, replace all 4 rc4558 ic's. in my case, i still felt a very small output signal from my pedal (equalizers, vol n gain ctrls r gud since they vary when i change the setting) so i suspected that one or 2 of my ic's were damaged. i only replace d last two op amps which my signal passes thru. i also had this problm with my marshall drive master. same diagnosis and solution. check your schematics
Anonymous
  • 11 Answers
  • Posted on Apr 10, 2009
SOURCE: my boss metal zone mt-2 pedal works...sometimes
too much dust and dirt in the switch .blow it out or spray it with contact cleaner into the switch and let it dry out
Dan Hickin
  • Posted on Jun 20, 2009
SOURCE: Beggining of loop missing on FIRST playback only, on Boss RC-50.
Ok, solved this problem by visiting roland U.S. site as the help offered in this country is useless. The instructions given by email would not have worked even after the update was installed. Luckily, there are instructions that come with the download. If you have same problem as me go to http://www.rolandus.com/products/productdetails.php?ProductId=772&tab=downloads&skip=true
and update the opperating system on the RC-50 to RC-50 System Update Version 1.01.
Then hold loop sync and phrase 2 button (think it was phrase 2) to change it to sound priority mode. Then it will play back correctly what you recorded on the first loop, rather than missing the first beat.
Am v.happy I have found this, as after much searching I can't find any other loopers out there that offer 3 seperate loop tracks and the ability to switch between them effectively. Plus, it's a very convenient size, better than a load of rackmounted stuff to haul around.
However.....
Another problem..
When hitting the reverse switch ( I assigned both external footswitch and the onboard Tempo pedal to reverse) the change is not instanteaneous. There is a second or so delay before it plays in reverse. Not a problem for most, I suppose, but I have a piece that switches rythmicaly between playing forward and reverse which means hitting a pedal in time and reverse/forwards changing immediately. I think they could do with another software update to solve this. Now I have to keep room in my enormous pedal board for the old rc-20, as that does the reverse as it should - when you hit the flippin switch!
Anonymous
  • 24 Answers
  • Posted on Sep 10, 2009
SOURCE: is it possible to upload my own Rhythm Guide
USB port for data/audio backup, import/export of loops as WAV files http://www.bossus.com/gear/productdetails.php?ProductId=772
Fred Yearian
  • 5603 Answers
  • Posted on Dec 04, 2010
SOURCE: My Boss RC-50 has stopped working. I used the
CHeck the voltage out of the adapter. It should be around 9 to 11 volts. If it is not, it is possible that the OC3 has reversed polarity AND a protector that put a short on an incorrect supply. If so, it could have damaged the RC50 adapter. If the RC50 adapter is putting out correct voltage, then I suspect the inout connector on the RC50 may be damaged or not quite seated. Visually inspect the connector first.
1helpful
I would like to record my own song without any pre-set chords, drums etc. Is this possible.
Please advise what model of keyboard you have purchased. Some do not allow recording without accompaniment. I might be able to help.
Dan
tip
RC looper and DR880 syncing.
RC-50 & DR-880 Setup
Rather than using the RC-50 to change patches on the DR-880, I have connected an FS-6 footswitch to both the RC-50 & DR-880. This gives me control of both units, I can select up & down through the patches easily.
Use a dual TRS connector and 2 stereo "y" cables connected to ports 1,2 & 3.4 on both units.
Once connected, you will need to assign the control function for each control port. I assigned Patch Decrease to CLT 1,2 & Patch Increase to CLT 3,4 on both units.
I then connected a MIDI cable from the RC--u control of start/stop & tempo via the RC-50 footswitches.
Can i add more memory to the rc50 loop pedal
You can make a backup on your pc and load back Default settings or restore to default settings. Normally you should have I quote ' with up to 49 minutes of mono recording time (or 24 minutes in stereo), the RC-50 can function as a song recorder as well as a looper'
I have the RC300 which has 3 hrs recording time. But when i reach the limit. I make a backup and load back in a initial default setup which I have downloaded somewhere. But you can also restore to default from the unit itself. Hope this helps
Apr 14, 2017 • Boss Rc 50
Hi Nothing happens when I connect my Boss RC-50 to my Windows 7 Packard Bell computer
The Boss RC50 is intended for guitar level signal. Your computer takes line-level. Hence your effects are "down in the noise' and you don't hear them.
Aug 04, 2011 • Boss Rc 50
I had recorded 16 complete songs of my own on a 512 mb sandisk sd card. When the card was almost full i removed it and recorded other new songs on another card. when i re-introduced the first card it had...
A very important thing when using these recording devices is to PROPERLY close the media. I would not panic at this point. Search for a forum regarding the Boss Micro BR and ask there as somebody may be able to help you recover the data. Read up on your manual about shutdown. I have Tascam recorders and I prefer to stop the recording and then when it is done I turn power off before removing the media. You may have to use a special procedure when introducing the nearly full card... even forcing it to load.
1helpful
2answers
My Boss RC-50 has stopped working. I used the power chord for my RC 50 in my Boss OC 3 pedal and then tried using the chord in my RC 50 again and it won't work. It won't even work with other power...
Dec 04, 2010 • Boss Rc 50
1helpful
How do I delete a track that has been 'written',
You didn't mention which model loop station you have so I'll direct you to the link:http://www.bossus.com/gear/productdetails.php?ProductId=477 The RC20XL for instance has an undo function.The RC50 has an update to ver.1.01 also that you can dowload. I hope this info helps.
I bought a used BR 532 Boss recorder - can't get a
I get an unformatted come on the screen on my Boss BR 532 when I swith on, and also when pressing record, although I can get drum machine to work and guitar go through it ok but no recording Hmmmm Erggg
Top Boss Music Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
ADMIN Eric
ADMIN Eric
Are you a Boss Music Expert? Answer questions, earn points and help others
