Kohler faucet
I don't know your exact model but most faucets screen filter can be screwed off for cleaning or replacement. Remove the screen filter with a pair of pliers and a rag. Once you get it loose, you should be able to unscrew with your fingers. Put the rag around filter before putting the pliers on it to prevent gouges and deep scratches in the chrome. IF you have a dishwasher, you can clean the screen filter on top basket of dishwasher if you have one. IF the screen filter looks bad to you, just replace it. Go to any hardware store ,take the screen filter with you and get help finding the right one. Once you have a replacement, hand screw it back on as tight as you can. IF it still leaks , use the rag and pliers to tighten it just enough to stop the leak in the screw parts. Good luck.
SOURCE: Low flow from Kohler K15160 spray kitchen sink
Are you sure the spray handle is allowing the valve to open enough to allow enough water through? The problem it seems like is physical or mechanical. I am assuming you get good water flow through the faucet itself.
SOURCE: how can be removed the bonet of de Kohler kitchen
try this if you need more help just ask... THX
http://www.us.kohler.com/onlinecatalog/pdf/1011154_2.pdf. The bonnet is screwed on and this should give you what you need. If you have any trouble just ask.
SOURCE: Can I remove the screen filter in the kitchen
Yes, the aerator (where the water comes out) can be unscrewed and removed from the faucet. I remove these and clean them out on a regular basis. If the aerator won't unscrew by hand, place a washcloth over the aerator (to prevent scratching) and carefully turn it with a pair of pliers. (Screw direction to loosen: Looking down on faucet, with pliers to the right-hand side, pull them toward you.) Make sure the rubber washer is properly placed in the top of the aerator after you have cleaned it out and you go to screw it back on. You normally don't need pliers to put it back on, as these are meant to be screwed on hand-tight. There might be several little parts inside the aerator to take apart and clean out, so be very careful to put these parts back together the same way they came apart. I find a toothpick is often useful to clean these out, as well as a cup of water to rinse them in.
SOURCE: I have a Kohler Clairette
Hi mkufs1,
Did you remove both screws from the handle?
If so, then try using a bit more muscle on it or rapping it with a wrench with a towel wrapped around it to protect the finish. A lot of times the handle will be stuck because of deposits built up from the leak.
Good luck. If the helps, I'd appreciate your vote. Thanks,
Handie Andie
SOURCE: My Franke pull out spray
first when you shut off the cold water supply and and the the hot water supply is the pressure equal if it is, most likely it is blocked with sediment at the connection where the hose attaches to the body of the faucet. you might have to remove the faucet from the sink to do it. first check the inlet supply's and tubing that go to the faucet
andrew
