20 Most Recent Price Pfister R89-7PC0 Chrome Portland Single Handle Pressure Balanced Show Questions & Answers
How do you adjust the scald guard, water needs to
Remove the handle and it will be a dial to remove and reinsert maybe a 1/4 turn counter clockwise to increae hot. just remember where you started at and adjust accordingly. Just put handle on turn on and see if it's at desired temp.
It should be a dial that may look like a little gear that will slide off and allow you to adjust tep.
1/24/2024 4:33:16 PM • Price Pfister... • Answered on Jan 24, 2024
Water run through the shower when its not supposed
that mean your faucet have been damage need to replace a new one. What you do is go the hardware buy a new faucet as your old one, dismantlel the head for both new and old. reassamble the new one to your shower.
10/11/2013 4:46:22 PM • Price Pfister... • Answered on Oct 11, 2013
2answers
I need a replacement cartridge # 17196-0100k for a
I have a single handle price pfister shower valve Model 17196-0100k .No cold water.It's coming hot on both sides.
3/23/2012 5:16:04 PM • Price Pfister... • Answered on Mar 23, 2012
My shower faucet doesn't get
I have the same problem but I did notice that I coulnt turn the handle all the way to hot. Can I adjust it and how?
2/19/2011 2:07:30 AM • Price Pfister... • Answered on Feb 19, 2011
Single handle shower faucet (price
Yes
2/16/2011 12:18:45 AM • Price Pfister... • Answered on Feb 16, 2011
I have an 11 year old, single handle shower
After you remove the chrome collar and plastic collar washer (behind the faucet handle), pry the beauty plate off the wall. Turn off the house main water supply. Remove the four screws and washer holding the cartridge and valve stem in place. Save the metal washer under the four screws for use with the new cartridge. Replace the stem/cartridge assembly and secure with the saved metal washer and four screws. Reinstall beauty plate, collar & collar washer, then handle.
2/8/2010 10:40:12 PM • Price Pfister... • Answered on Feb 08, 2010
Water leaks out of shower head during tub use
The pipe to the tub spout is either restricted or the valve was placedd too high causing some of the water to come up and out of the shower head instead of it all flowing out of the spout.
11/12/2009 4:43:48 AM • Price Pfister... • Answered on Nov 12, 2009
My Pfister tub and shower tap does not blend the
Problem solved, thanks.
10/26/2009 1:16:28 AM • Price Pfister... • Answered on Oct 26, 2009
R89-7tuc thermostatic valve a little bit cold on
Take off the handle and the cover plate usually there is an adjustment under the cover plate.
10/19/2009 9:44:45 PM • Price Pfister... • Answered on Oct 19, 2009
I have a Price Pfister Model no. 808 DK00 single
It's likely that you have some sediment that has accumulated in the cold water valve and has clogged it. The model number you have cited above is only for the trim (rather than for the valves behind it). Assuming that you have a Price Pfister valve, they don't have built in filters, so you're probably going to have to either clean or replace the valve.
9/18/2009 5:24:32 PM • Price Pfister... • Answered on Sep 18, 2009
Price pfister single handle shower faucet
home depot has all the parts for price fister
2/4/2009 2:34:04 AM • Price Pfister... • Answered on Feb 04, 2009
How to reversing stem rotation for Pfister 910-030 cartridge
For Pfister 910-030 tub stem: Take off the 1/2 white clip at the end of the post, it's next to the 12 splines that hold the handle on. Its a little tight but can be done after the stem is installed. Flip it over and slip it back on aligning the notches properly first. A 2" long 13 mm socket slipped over the end and tapped lightly with a hammer helped me get it set.
11/13/2021 5:09:55 PM • Price Pfister... • Answered on Nov 13, 2021
If we put the wax
If you are installing a wax (doughnut) seal to connect the toilet to the main drain, then the wax ring should be big. It should 'squish' to seal correctly. You may not need it, but I've known plumbers to install two of the seals at once for extra gap-filling. Just install the seal, sit on the toilet to compress the seal into place and then install the bolts to the floor. Done!
10/23/2017 9:24:05 PM • Price Pfister... • Answered on Oct 23, 2017
Toilet keeps trickling water in the tank when u flush
you need a new tank kit, pick one up at your local Menards
11/19/2014 7:35:27 PM • Price Pfister... • Answered on Nov 19, 2014
How to clean the screen filter in the kitchen faucet
I don't know your exact model but most faucets screen filter can be screwed off for cleaning or replacement. Remove the screen filter with a pair of pliers and a rag. Once you get it loose, you should be able to unscrew with your fingers. Put the rag around filter before putting the pliers on it to prevent gouges and deep scratches in the chrome. IF you have a dishwasher, you can clean the screen filter on top basket of dishwasher if you have one. IF the screen filter looks bad to you, just replace it. Go to any hardware store ,take the screen filter with you and get help finding the right one. Once you have a replacement, hand screw it back on as tight as you can. IF it still leaks , use the rag and pliers to tighten it just enough to stop the leak in the screw parts. Good luck.
9/1/2014 4:33:35 AM • Price Pfister... • Answered on Sep 01, 2014
How do I remove a Pfister Marielle metal lever handle?
Bear with me, please. Adjust the temp at the physical valve? Interesting at the least. Never seen or heard of that. They come up with something new everyday. I'm going to follow this for my own benefit. Thank you. And good luck. - Ned
7/23/2014 1:54:02 AM • Price Pfister... • Answered on Jul 23, 2014
Price Pfister R89-7PC0 Chrome Portland Single Handle Pressure Balanced Show Logo
18 questions posted
Top Price Pfister Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Price Pfister Home Expert? Answer questions, earn points and help others
View Most Popular
Price Pfister Home
  • Price Pfister Home
Most Popular Question
need replacement cartridge 17196 0100k
  • Home
