Nikon D90 Digital Camera with 18-105mm lens Logo
A
Anonymous Posted on May 29, 2014
How do i slide a nikon d90 lense on - Nikon D90 Digital Camera with 18-105mm lens
Bart Pulverman
Level 2:
Guru:
  • Nikon Expert 362 Answers
  • Posted on Jun 08, 2015
Bart Pulverman
Nikon Expert
Level 2:
Guru:
Answers
362
Questions
0
Helped
83821
Points
625
If you do not have a manual for your D90, you can download it free from the Nikon USA website by following this link: Download Center. Go to page 25 in the manual for complete illustrated instructions.
5 Related Answers
Glyn Kendall
  • 146 Answers
  • Posted on Jul 16, 2009
SOURCE: WILL THIS MODEL JELL WELL WITH THE NIKON 50mm
The Nikon D90 works well with the Nikon AF 50mm lenses and most other brand Nikon fit AF lenses. If they are not AF you will lose autofocus and metering.
Do you know that on the D90 the lens becomes a 75mm but the aperture stays the same, so for instance the 50mm f/1.8 is a 75mm f/1.8.
Anonymous
  • Posted on Dec 06, 2009
SOURCE: Nikon D90 ERR message after taking picture -
I have the same problem like you. I take 3 photos with my Nikon D80 and this message came out : ERR ... I have NO idea what should I do ? ! Please help me... Lucas
Anonymous
  • 667 Answers
  • Posted on Dec 13, 2009
SOURCE: Hi, I have just bought a Nikon D90 and am
The lens has a plastic mount. Look closely at the rear of the lens, you may see that the tabs that hold it to the camera have broken off. You can get a replacement mount at UScamera.com or Nikon in California
Gary Maitland
  • 117 Answers
  • Posted on Feb 24, 2010
SOURCE: Nikon D90 with Sigma 18-200 lense - Target moves when turning ON
This is the OS setting up its normal
Anonymous
  • 154 Answers
  • Posted on Jun 19, 2010
SOURCE: Will not shoot. F-- seen on lcd screen. After a
it is the best to take them both to the place it was bought , it should be in waranty do not mess with it your self
1helpful
D90 wont shoot in auto mode. gives me r21 error. Manual mode works fine
Did you switch the Focus-mode selector to MF?
It is the switch with number 8. Perhaps you are used to switching on the lens, but on the body is also a switch. Normaly used for the older AF lenses.
Does tamron 80-210mm work for Nikon d90
Tamron makes their lenses with a variety of lens mounts. If your lens has a Nikon mount then it will mount onto the D90.
1helpful
Will the Vivitar SI 70-210 mount on my Nikon D90. Will the AF work properly? Thanks
Vivitar makes lenses for a variety of cameras, so a lens for a Canon, for example, will not fit onto a Nikon. Assuming the Vivitar lens has a Nikon mount, then yes, it will mount on the D90 and yes, it will autofocus properly on the D90.
1helpful
I have a Soligor C/D 28 - 200 mm, f3.5 - 5.3 Macro lens used quiet well on a Minolta XG1 and want to know whether I can use it on a Nikon D90 DSLR and if so, where can I source an adapter. Is it worth the...
The lense will probably work with an adapter. try ebay. i purchased one for my canon lenses for macro work. note that the focal length of the nikon is 46.5 and the minolta is 43.5 and infinity will not work with out an adapter with a correcting lense. you will find a adapter with out a lense will work fine for macro.
Jul 19, 2010 • Cameras
2helpful
Do all nikon lenses mount the same or are the digital cameras difrent? I own a nikon 6006 camera and want to know if i can use my lenses with the D90 or do I need to get diffrent lenses?
Yes and no. Physically they will all fit (with very rare exceptions, such as the 6mm f/2.8 fisheye).
Most Nikon dSLRs have a sensor that is smaller than a frame of 35mm film. What this means is that you end up using only the central area of each lens. In effect this means that each of your lenses is effectively 1.5 times longer. A 200mm lens on a digital camera will give you the same angle of view a 300mm lens on a film camera gives you. The D3 family and the D700 are the exceptions, behaving similar to a film camera in this respect.
Older Nikon lenses do not have the electronic circuitry necessary to communicate with newer cameras. In the case of the D90, this means that such lenses will not communicate with the camera's exposure meter. They can still be used in Manual mode, but without assistance from the meter. You'll need to move up to a D300 if you want to meter with such lenses.
Bear in mind that lens technology continues to improve every year. Given an old lens and a new lens of similar focal length (or zoom range), the new lens will almost invariably outperform the old one.
1helpful
WILL THIS MODEL JELL WELL WITH THE NIKON 50mm LENSES (NORMAL) & OTHER BRANDS OF 50mm LENSES (NORMAL) THAT IS WITH NIKON D90 DSLR
Tele converter option for Tamron 28-75mm f2.8
This is a lens for Sony/Minolta cameras. It is not compatible with the Nikon D90. Hence a Teleconverter for Nikon will not work on this lens to mount it to a Nikon D90.
Lense will not work with SLR Nikon D90
This lens is too old for the D90, it has not got the electronics for metering and autofocus.
You can use it manually in M mode but you will have to set the aperture and shutter yourself.
The D90 manual has a section on compatible lenses, page 228 in my version.
This recommends CPU lenses for the D90, type G and D.
3helpful
Compare the Nikon d80 to the new d90. Can I use all my manual focus lenses from my Nikon film cameras? Also, all my filters and flashes.
All old lenses will work on the D90 the same way they work on the D80. Filters depend on the lens -- they either fit or they don't -- the camera has nothing to do with that. I wouldn't use old flashes on new DSLRs.
There really is no difference between the D80 and the D90 as far as lenses and flashes are concerned.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
