Vtech CS5121 Cordless Phone Logo
A
Anonymous Posted on May 27, 2014
How do you enable call forwarding to your voice mail on cordless?
Incoming calls go straight to voice mail. voice tells caller , not excepting calls. accidently push *53
Hi Patriciarn77,
This is happening because all your calls have been diverted to voicemail.
Go to your phone settings, then call settings. In the call divert menu, select 'cancel all diverts'.
When you have done that, you call diverts to voice mail would be inactive.
I hope that was helpful?
If it was please rate this answer to enable improve my ability to solve others problems. Have a wonderful day.
My nokia 2330 go's stright to voicemail when sombody calls
You must have activated the call divert function or maybe your line is currently invalid from your network and so any incoming call is forwarded to voice-mail so your callers can leave you a message pending when you come back on.
to solve this, you have to go to settings and then call settings. From here, you must deactivate the divert all calls to voice-mail function. This would enable your calls to come straight to your phone and not to go to voice-mail.
If you are having problems doing this, you can call your customer care service and ask them for further assistance.
Hope this helped?
Jun 19, 2011 • Cell Phones
I get my message to voice mail not to my answering machine at home. why
your service provider might come with voice mail system, you need to log on to your provider website and disable the voice mail or you can setup your provider voice mail to 4, 6 sound and your Digital Cordless to 2 sound before the voice mail pick up and you will see the difference.
4helpful
NEED TO SET UP MY VOICE MAIL
Hi,If your account is enabled for voice mail, you can receive voice messages in your Inbox and also in a text message on your mobile phone. Both the message in your Inbox and the text message will include a preview of the voice message in text.
How do I set up voice mail?
1. Go to https://outlook.com to sign in to your mailbox, go to Options > Voice Mail tab, and then click Set Up Now.
2. When you set up your voice mail:
* You'll register your mobile phone number.
* Text messaging is set up. You can choose to be notified in a text message that you have voice mail or have missed a call.
* Call forwarding is set up so that your mobile provider forwards calls you receive to your voice mail. So if you don't answer your phone, your phone is busy, or you're unreachable or unavailable, the caller will be sent to your voice mail. After your personal greeting is played, the caller can leave a voice message for you.
* You can test whether your voice mail has been set up correctly by dialing your mobile phone number from your mobile phone. This verifies that call forwarding is correctly set up with your mobile provider.
How do I change my voice mail after I've set it up?
After you've finished setting up voice mail, you may want to:
* Change the mobile provider's voice mail number so you can use the key your provider has reserved for accessing voice mail to access your voice mail. For details about how to do this, see Changing the Number You Call to Access Your Voice Mail.
* Create a contact on your mobile phone. For details about how to do this, see Create a Contact for Voice Mail.
* Assign a speed dial key to the contact you create for Outlook Web App voice mail. For details about how to do this, see Set Up Speed Dialing for Voice Mail.
What else do I need to know?
* The voice mail service is available only to certain customers in certain regions. If you can use voice mail, you'll see a welcome message in your Inbox telling you how to set up voice mail for your account.
Thanks for using fixya...
Jan 20, 2011 • Cell Phones
My uniden cordless phone says vm on the screen. What does that mean?
It is voice mail and some time you checked voice mail on your cordless phone but light will keep flashing that you need to check your voice mail. if it does not fixed then You need to also delete the voice mail from any voip device and it should turn off blinking lights and will clear vm message.
One of my extension's voicemail won't pick up.
Hi, make sure that the phone is set to go to Voice Mail, 601 *** ( Voice Mail number) forwards all calls, 602***(Voice Mail no.) is to forward callers to Voice Mail when that extension is busy or unanswered. To clear forwarding 600. I have sent you a link to 1 of our videos on YouTube to help, or take a look at www.abbeytelecom.com
1helpful
Recorded incoming voice mail message download
I called my telephone server of voice mail and they led me through process.
2helpful
3answers
Voicemail
Press and hold the "Mute" or "Clear" button until the handset beeps to clear the New Voice Mail allert.
35helpful
7answers
Displays new voice mail and VMWI constantly blinking when no voice mail
Subscriber is T-Mobile@Home. First, cleared all messages from T-Mobile voicemail.
Now to fix your GE phone:
Push the program key. Select Handset Setup Push the program key Select Default Settings Push the program key Select 1 Yes. Push the program key
Hope this helps.
Caller ID telephone GE 25922 5.8 GHz Cordless
I dialed my own phone number and that accessed my voice mail.
Top Vtech Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
