Right turn signal no power at plug for trailer right turn signal or right side brake
SOURCE: 03 Yukon denali park brake warning wont turn off
hi for info the brakes warning light on dash is also an indication that brake fluid level is low? or there may be a leak resulting in fluid level drop ? also considering age of car you may need to inspect brake pads wear ? if your car has low brake pads wear indicators attached to pads ? or the hand brake switch req's checking to ensure it is being pushed to off position when h/brak is down ? so fluid level low is the obviouse 1st check as fluid will displace from reservoir as pads wear low hence the level indicator on fill cap trips on may i suggest if it is low level b4 you top up? check your b/pads if you have not done so recently? or replaced since new ? hope this helps you locate problem best wishes from the uk
SOURCE: service brake booster display
Your brake booster is the heart of your power brakes. It runs off a vacuum from the intake to booster. Your brakes will still work as long as they have fluid. They'll just get stiff. It probably means you need a new one
SOURCE: no brake/hazard lights,have running/turn signal lights
Suggest you change hazard flasher 'can' first, then go to the hazard switch. I'm betting it's the flasher can.
SOURCE: trailer brake controller problem
I found the problem. Talking with a technician from the controller company, we determined that it was a fuse problem. I found that the fuse to the CHMSL was blown.
SOURCE: gmc yukon has the abs & parking brake light
you have to fix the problem with ur brakes- first check the wiring ,connectors and connection clips to the abs sensors and modulator if looks ok than have truck scanned some auto stores such as auto zone / advanced auto do it for free the code will give u a start point towards fixing ur problem--visual inspection of brakes doesnt always show problem
4-Way
5-Way
6-Way
7-Way
Green
Yellow
Brown
White
Red
Blue
Purple
Right Turn & Brake
Left Turn & Brake
Tail Lights
Ground
Backup Lights
Electric Brakes
Auxiliary Power
Green- Right Turn and Brake
Yellow- Left Turn and Brake
Brown- Tail Lights
White- Ground
Red- Reverse (Back Up) Lights
Blue- Electric Brakes
Purple- Auxiliary Power
It sounds like your green and yello wires are shorted together somewhere along the length of the harness. I would check the wires on the trailer first. Easier yet, if you have another trailer to connec or access to another to use for testing, connect to it and see if the problem repeats; if it does the trouble is in the vehicle's wiring.
