Cell Phones Logo
A
Anonymous Posted on May 24, 2014
How do u turn the light off wireless portable battery pack SKU 04076
  • Mark Simonds
    Mark Simonds Dec 15, 2017
    Oh my gosh thank you, haha!!
Chris Thomas
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 03, 2014
Chris Thomas
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1515
Points
Double click the power button.
  • Felix Mendez
    Felix Mendez Dec 25, 2014
    How do you charge it?
Robert Mankel
Level 1:
  • Posted on Sep 01, 2014
Robert Mankel
Contributor
Level 1:
Answers
Questions
0
Helped
1515
Points
0
Double click power button
Felix Mendez
Level 1:
New Friend:
Problem Solver:
  • Posted on Dec 25, 2014
Felix Mendez
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
0
Helped
1515
Points
How do you charge it?................
Nancy McDonough
Level 1:
  • Posted on Jul 10, 2014
Nancy McDonough
Contributor
Level 1:
Answers
Questions
Helped
1515
Points
0
I have the very same problem Have you had any answers?
  • Franklin Griffis
    Franklin Griffis Jul 14, 2014
    Any luck turning it off? Having the same issue
Just wireless battery charger #04076 will not recharge when plugged in. Do I have to push the power button a certain # of times?
This is for a cell phone. It just plugs into the cell phone and the wall socket, there does not appear to be a button.
See description here
Just Wireless Mobile Phone Battery Charger Black 04407 Price 15 99 tossbuy...
Mar 04, 2015 • Cell Phones
How do. I use a Wireless product sku 04076?
It depends on what it is fore, there are several items that fit this description. I would start with name and model number and enter it into Google.
How to install the 9V battery in the PYLE PWMA200?
The 9V battery is for the mic or the transmitter from what I can tell. According to the manual, the bottom of the mic is where the battery compartment is located, and it unscrews. You can get the manual here: http://www.pyleaudio.com/sku/PWMA200/Rechargeable-Portable-PA-System-with-Wireless-LavalierHeadset-MIC-and-1-Wired-Mic
Ho w to fix x box from controller to x box is really slow how to make it normal
Learn how to connect a wireless or wired controller to your Xbox 360 console.
Connect a wireless Xbox controller
  1. Turn on your console.
  2. Press and hold the Guide button on the controller until the controller turns on.
  1. Press and release the connect button on the console.
Xbox 360 E console fbbfb609-f7ed-4e6e-bd35-7543b1c20d61.png?n=xbox360-connect-m-s.png Xbox 360 S console Original Xbox 360 console 342c6e70-9e56-43d8-bb3a-05f5411040bd.png?v=1#xbox360s-connect-m-m.png 170df81e-0a79-49be-8236-a0fb68eec37b.png?v=1#xbox360-connect-m-m.png
  1. Within 20 seconds, press and release the connect button on the controller.
  1. When the lights surrounding the power button on the console stop flashing, the controller is connected.
On the Xbox 360 S console, each connected controller is assigned to one of four positions. Each position corresponds to a lighted section around the console power button and the controller Guide button. On the 360 E console, a solid green light on the front of the console indicates that the controller is connected. To determine the player position associated with your accessory, look at the ring of light that surrounds the Guide button on the controller.
c9341988-8ed5-4217-9b87-353de50efbec.png?v=1#connect-xbox-controller-m-m.png 5e4ab6ab-8cb0-41e6-a037-b88221a430c7.png?n=connect-xbox-controller-360-m-s.png
71add0b7-ddf2-4439-b4b4-f50f156d92b7.png?v=1#controller-batteries-m-m.png If the controller does not turn on, check the batteries. Insert fresh AA batteries, making sure they are correctly positioned in the battery case.
You can also use the Xbox 360 Play & Charge Kit or the Xbox 360 Quick Charge Kit to power the controller. Learn more about Xbox controllers and chargers.
To connect additional controllers, follow these same steps again. You can connect up to four controllers to the console. Each connected controller is assigned a position that corresponds with the lighted sections that appear around the console's power button and around the Guide button located in the middle of each controller.
  • To disconnect a wireless controller, press and hold the Guide button for three seconds, and then choose to turn the controller off.
  • When you turn off the console, the controller will reconnect the next time you turn on the console.
  • The controller can be connected to only one console at a time. You can connect the controller to a different console, but the connection to the previously connected console will be lost.
Connect a wired Xbox controller
5fb17f50-7448-45d5-a294-9ea90994f55b.png?v=1#controller-wired-m-m.png Plug the Xbox 360 Wired Controller into a USB port on the Xbox 360 console. There are two USB ports on the front of the console. To disconnect the controller, pull on the connector, not the cable.
cbe46bf0-3a46-4d53-9d8c-6697aa57622a.png?v=1#controller-cable-release-m-m.png The cable on the Xbox 360 Wired Controller has an inline release. The inline release on the controller cable is a safety feature designed to reduce the chance of the Xbox 360 console falling if the cable is pulled.
Wireless controller troubleshooting
If your wireless controller disconnects or cannot connect to your console, see Xbox 360 Wireless Controller disconnects or can't connect.
If your wireless controller does not turn on or loses power, try the following solutions:
Solution 1: Replace the batteries
Insert a new set of AA alkaline batteries into the Xbox 360 Wireless Controller, and then try to turn it on.
Solution 2: Try a different battery pack
If you have another Xbox 360 Wireless Controller, take the battery pack off that controller and attach it to your controller. Then try to turn your controller on.
If your controller works with the different battery pack, your original battery pack might be defective. If your controller is under warranty, you can order a replacement battery pack from Xbox Support . See the Assistance section at the bottom of this page for more information.
If your controller is out of warranty, you can buy a new battery pack from a retail store.
Solution 3: Try a rechargeable battery packIf you or a friend has an Xbox 360 Rechargeable Battery Pack, attach that battery pack to your controller and try to use your controller. If your controller works with the rechargeable battery pack attached, you can buy a new battery pack from a retail store or order a replacement battery pack from Xbox Support. See the Assistance section at the bottom of this page for more information.
Parking lights come on when key is turned on but bike wont turn over. New battery just installed.
Try to jump it with one of those portable battery packs. If the starter works then, it's a problem with the new battery or it's cabels or connections.
5helpful
3answers
Portable DVD Player
I wrote to Walmart.com. The corporate office. They contacted my local store and the store replaced my machine with a brand new magnavox even though my machine was 1 year old, Try it. They told us that customer satisfaction was guaranteed. They also told us that the company was out of business.
Hi-- This is actually a problem with the Canon LK-51B battery pack that goes with the iP90v portable printer. We've charged up the battery pack and all the lights have gone out, indicating full...
electronics should not be relied on to realy confirm u need to use a second battery pack to connect ur printer n see if the same thing will occure. i guess the battry inside d pack may be dead even though its a new one.
PSP will not turn on
Have you tried ejecting your battery pack? I've had a problem like this. But I don't recall the green light coming on for 15 seconds. Anyway, try ejecting the battery pack and putting it back in. If that doesn't work, then... I tried.
2answers
Pink portable dvd player durabrand
It sounds like your battery went dead. maybe you should consider replacing the battery.
Top Just Wireless Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Just Wireless Cell Phone Expert? Answer questions, earn points and help others
