Minolta bizhub 180 Black and White Copier Logo
A
Anonymous Posted on May 21, 2014
Bizhub 164 m2 - Minolta bizhub 180 Black and White Copier
Tareq Bin Mostaq Mostaq
Level 3:
President:
  • Minolta Master 1,449 Answers
  • Posted on Jul 23, 2014
Minolta Master
Level 3:
President:
Answers
1449
Questions
31
Helped
614586
Points
3628
Press the Utility button,
then Stop 0 0 Stop 0 1
then scroll to Clear Data, and then Supplies Data and clear.
You must be aware that clearing this counter clears the drum, developer and other counters.
Which are very important for copy quality, and not replacing them may cause more harm than good.
Konica minolta bizhub 164 showing M2 maintanaince call
You need to replace 1st the consumables before simulation/reset to prevent further damage to Bizhub 164.
BIZHUB 164 error M2 what have I to do
Replace the developer and the drum make sure counters are cleared first and that Gradation adj is run along with Toner adj
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
replace the drum and developer and then reset the counter
Konica mintola bizhub 164 maintainace call (M2)
replace the drum and developer and clear the counter also ensure you run the F8 after developer been replaced and new drum are installed
How to solve M2 in bizhub 164
Konika Minolta BizHub 163 - Error Code M2
then Stop 0 0
then press again Stop 0 1
2answers
CARA RESET M2 BIZHUB 164
bagaimana cara reset bizhub 164 error c2558 mohon penjelasannya
2helpful
Konika minolta bizhub 164 how to enter into service mode
KONOCA MINOLTA 164
ERROR FOR MAINTANANCE CALL(M2) ,PLEASE SOLVTHE PROBLEM
17helpful
2answers
Desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
Top Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
