20 Most Recent Konica Minolta bizhub 161f All-In-One Laser Printer Questions & Answers
If the problem persists initialize the Fax board (Service Mode =>Fax =>Initialization
Konica Minolta... | Answered on Apr 17, 2019
firstly press menu then press quick setting then twoo time press left arrow then again press quick setting then press left aroow and after this press right arrow service mode will open at ur machine select "Maintenance Counter" now in this option select, 0 and press ok.
Konica Minolta... | Answered on May 19, 2017
maintence call(m2) call service
Konica Minolta... | Answered on May 07, 2017
on a Bizhub 161f?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konica Minolta... | Answered on Jun 19, 2016
Power off the machine, ensure the sub power switch is on that is the one on the control panel, now hold down the utility/counter button and turn on main power switch, wait to see trouble reset on screen the touch get OK then power off. Wait 10 second power on. if code comes back replace the fuser unit do not reset again or the machine can catch on fire the code you are resetting is for the fuse the HOT Part, that could ruin a perfectly good day
Konica Minolta... | Answered on May 25, 2015
The bright that normally come on under the big glass is having issues, replace the scanner assembly can't just get the lamp.
try this web site for starters
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
found it. it's "sysadm"
Konica Minolta... | Answered on Jan 29, 2015
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
Konica Minolta... | Answered on Oct 17, 2014
hi its link for driver
http://www.konicaminolta.eu/en/business-solutions/support/download-center.html
and you may find here drivers
Konica Minolta... | Answered on Apr 21, 2014
C0500 is a warm-up error on those little machines. Try holding the stop button while switching on, that should reset the code. It sometimes happen if it's kinda cold, or when the power dips. If the code comes back, you'll have to replace the fuser unit.
Konica Minolta... | Answered on Oct 21, 2013
maintenacne call (m1)
Konica Minolta... | Answered on Jun 03, 2013
That is just the format it saves it in. Open the document and tell it to save as and you can change the: "Save as type:" to the type of document you want.
Konica Minolta... | Answered on Apr 01, 2013
Open the front cover.Pull out the PHD carefully and install the new one.
Konica Minolta... | Answered on Feb 15, 2013
Konica Minolta bizhub 161f All-In-One Laser Printer Logo
58 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
bizhub Konica Minolta
  • bizhub Konica Minolta
Most Popular Question
message call service m1 clear
  • Office Equipment & Supplies
