My px 820 has an error formatting. when I took out the batteries it does not on anymore with no display and led flashing red and yellow constantly. Help please. It is not detectable with computer either
SOURCE: Sony ICD-P210, ERR ACCESS message
Your problem may have been caused when you removed the unit from the PC without using the "safely remove hardware" option.
What you need to do is download the latest version of Digital Voice Editor (I think we are up to 3.1 now)
When you connect the ICD unit it will probably give you a number of access errors
Ignore them and go to the IC Recorder Menu. Select WHOLE and DELETE. Delete everything.
After a minute or so the unit will come to life and you'll see the Directories that are standard in your unit.
Remove the hardware from the computer (safely! by closing the program first) and turn the unit off.
Now turn it on...... Bingo!
SOURCE: i have sony icd-px820 voice
You have to format it as FAT, not FAT32.
Then safely eject it from your system and unplug it. It will say ACCESS for a while and then be back in function.
Good luck.
