Question about Lenovo Computers & Internet
Lenovo z570 bios bin file - Lenovo Computers & Internet
SOURCE:
  • 162 Answers
SOURCE: lenovo g530 4151 - restore bios from USB or CD ?
Hi, What I would best sugget you if you this kind of issue is to restore your system to its original settings, just look for the small button just beside the power button on your keyboard, it has an arching arrow logo, that key is what we called One Key Recovery that would restore your system to its original factory settings. but just a hint it would also delete everything on your computer so consider bucking up every important files taht you have before proceeding with the recovery. also make sure that the ac adapter is plugin before you press the one key recovery button then it will give the options to choose from, just choose one key recovey then proceed with the factory default recovery, thats it it would now proceed with the system factory default restoration. If you still need some clarifications regarding this issue you could also call the tech support hotline of lenovo
US/Canada: Available 24/7 1-877-4LENOVO (1-877-453-
6686)
Australia: Available 24/7 1300-557-073
New Zealand: 9am-9pm Mon-Fri 0800-446-833. Hope that helps you.
Posted on Jun 02, 2010
nonontech
  • 4737 Answers
SOURCE: Hi... I have a HP ProBook
Could you please let me know what operating system is installed on your system? If I am right, it's not mentioned here. Even if you install/upgrade the bios from cd-rom or usb drive or floppy disk, there are different Update file for different O.S. If you are sure about the Bios update file, then try booting with a CD or using a usb drive.
I too hope that you followed the procedure : download > double-click > make bootable disk > restart > continue with the update and you should not interrupt the process in any way (never should be). But first, before you double-click (make the bootable disk), set the first boot option to floppy disk or cd-rom or usb.
If you can and if you doubt about the bios version compatibility, please send me the link from where you download the Bios Update file. Let me take a look and confirm it to you.
You have to understand that Updating Bios is risky, it's not so simple as most people think and only the instructions (without a tech) is not recommended, no one can guarantee that the bios flashing will be successful and it's vulnerable, sometimes it'll never return once it's flashed improperly or if the process is incomplete. I recommend you to get it done from a HP Center or call a tech to inspect the machine personally and perform the task. I don't mean you are not and you cannot, but if you are sure what exactly you are doing, you'll end up wasting time and money.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Posted on Sep 01, 2010
SOURCE: lenovo z570 volume
drivers bad to be replaced or the volume key is stuck
Posted on Mar 11, 2012
SOURCE: Lenovo Ideapad Z570: Battery indicator shows the Power is plugged in & charging. But the Battery charge percentage doesn't increase. How to fix this?
The battery might be nearing the end of it's useful life and needs to be replaced. The battery only lasts for so long then it has to be replaced.
Buy a battery on ebay base on your computer's Make and model, not the model of the battery.
Posted on May 15, 2012
jadiazq
  • 2878 Answers
SOURCE: want to change compability to AHCI mode in lenovo z570 ideapad
This is a setting in you BIOS. Try changing to AUTO under the SATA drive settings by pressing F key during boot. It will be noted on screen during startup.
I would stay away from a OS upgrade till your are certain all hardware and software is compatible. It is a lot of work if it does not work properly.
Posted on Nov 30, 2012
Lenovo z570 screen blank when boots
Could be many issues, you need to give more information. Mine lenovo does the same thing when it boots. You might just need to wait for a little longer for the desktop top come up.
Other than that, you might need to reinstall Windows.
Aug 30, 2014 | Lenovo IdeaPad Z570 Notebook
Lenovo z570 power and on/off switch leds blik
Sounds like your battery is on its last leg.
Mar 25, 2014 | Lenovo IdeaPad Z570 Notebook
How to reset bios on lenovo z570
Open the BIOS and select Default settings. Press F10
Jan 31, 2014 | Lenovo Computers & Internet
Plz send y330 lenovo whitout graphic bios bin file
Most manufacturers allow you to obtain this from their website. I would imagine this is also the case for lenovo, but if not, you can always put a custom BIOS on the laptop.
Oct 24, 2013 | Lenovo Computers & Internet
I dont have a bios password key and i want to remove bios password
Tricky you need to remove all power (including the on board battery) and leave for at least 24 - usually 48 hours. Then plug back in all batteries and you should be OK.
Oct 07, 2013 | Lenovo IdeaPad Z570 Notebook
P4vvm2 bios update file
Your drivers can be found here: http://support.lenovo.com/en_US/research/hints-or-tips/detail.page?&DocID=HT072735 BE ADVISED: A BIOS update cannot be reversed easily , READ the instructions VERY carefully. One wrong step and you have a expensive paperweight.
May 26, 2013 | Lenovo IdeaPad Z570 Notebook
Want to change compability to AHCI mode in lenovo z570 ideapad
Nov 30, 2012 | Lenovo IdeaPad Z570 Notebook
Lenovo z570 volume
Mar 10, 2012 | Lenovo IdeaPad Computers & Internet
Computers & Internet Logo
173 people viewed this question
Top Lenovo Computers & Internet Experts
Alun Cox
Ekse
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
