SOURCE: lexmark x5470
A Right Cartridge Incorrect message generally
indicates a communication error between the All-In-One and the
cartridge. This can be caused by a faulty cartridge; however, it may
be due to a simple interruption in the communication between the
cartridge and the All-In-One.
The procedures below will help you to identify the cause of the error and resolve the issue.
Rebricking the All-In-One and Resetting the NVRAM
NOTE: The embedded links in the table lead to specific troubleshooting documents.
Step
Action
Power off the All-In-One and remove the power brick from the back of
the unit. Wait 20 seconds. Then reinsert the brick and power the unit
back on.
Did the error message return?
Yes: Continue to step 2.
No: Print a test page. If the test page prints, the error is resolved.
Reset the NVRAM of the All-In-One
Yes: Continue to Checking the Cartridges.
Step
Action
Open the top cover of the All-In-One. Remove both cartridges. Close the top cover.
Power off the All-In-One and remove the power supply brick from the back of the unit.
Reinsert the power supply brick into the back of the All-In-One and power the unit back on.
Does the error message reappear?
Yes: Skip to Contacting Lexmark. There is a hardware issue with your printer and you need to contact our technical support center.
No: Continue to step 4.
Clean the cartridge contacts (click here for instructions) and the AIO carrier contacts (click here for instructions). Continue to step 5.
5
Power the AIO on, reinsert the black/photo cartridge, and close the top cover. Power the All-In-One off and then back on.
Yes: Power the unit off and try step 5 with another black/photo cartridge. If the error persists with the new cartridge, proceed to Contacting Lexmark.
No: Continue to step 6.
6
Power the AIO on, reinsert the color cartridge, and close the top cover. Power the All-In-One off and then back on.
Yes: Power the unit off and try step 6 with another color cartridge. If the error persists with the new cartridge, proceed to Contacting Lexmark.
No: Try printing a test page. If the test page prints, the error is resolved
SOURCE: Printer says cartridge incorrect, but is the right one...what do I need to do?
There are a small number of #23/#24 cartridges that are not properly recognized by the printer. Lexmark has a firmware upgrade to correct this issue.
The upgrade for the X3430 is available from Lexmark at:
PC: http://www.downloaddelivery.com/downloads/misc/Firmware_F061909_3430Series.exe
Mac: http://www.downloaddelivery.com/downloads/misc/Mac_MCC_J062309_01.Zip
To install the firmware upgrade,
1. Make sure the printer is ON and connected with a USB cable.
2. Download and run the appropriate firmware upgrade for your computer.
3. Be sure not to disconnect or power off the printer until the upgrade is complete
When the update finishes the printer will restart and will accept the cartridges. Please contact Lexmark support if this does not fix the problem.
SOURCE: MESSAGE SAYS RIGHT CARTRIDGE INCORRECT
Hello there:
what this is refering to is that the cartridge is either not the right one for the printer or the device is having a problem with that cartridge i would remove the cartridge and verify that it is the right one that goes in their and also since youare having the cartridge out i would clean out the contact area to get rid of the old ink that may be sitting on the contact areas ok
best regards Michael
SOURCE: i put new printer cartridges in;left catridges lexmark x6570
maybe the cartridges you put are nt compatible to the printer or not properly place
An 'incorrect cartridge' or 'missing cartridge' error can be displayed if:
http://support.lexmark.com/index?page=content&id=SO4738&segment=SUPPORTproductCode%3D&productCode=LEXMARK_X4875&locale=EN&userlocale=EN_US
X4850
