Whirlpool GEW9200L Electric Dryer Logo
A
Anonymous Posted on May 07, 2014
My Whirlpool Duet Dryer is turning but not drying
5 Related Answers
Anonymous
  • 36 Answers
  • Posted on Dec 16, 2008
SOURCE: Whirlpool Duet Dryer WED9600 Beeping during drying
Dear Customer
Please perform the following
please rate this,thank u
lenwest
Len West
  • 150 Answers
  • Posted on Jan 30, 2009
SOURCE: Whirlpool duet electric dryer - drum turns; no heat
Turn off the breaker and check the heating element.
for more help go to live chat.
hope this helps
len west
Anonymous
  • 66 Answers
  • Posted on Dec 12, 2009
SOURCE: Whirlpool Duet dryer not drying like it used to
If your duet isn't heating properly and you have taken care of the lint problem then you could have one of two problems. Either you have a bad heating element or you have a bad fuse or temperature sensor.
If your dryer is not heating at all then it is most likely the fuse or temp sensor. If it is heating and just not enough it is probably a bad heating element.
Both problems would require a repairman to come and fix normally, however if you believe it is the heating element that can usually be replaced by the homeowner without too much trouble. Just make sure to ask where it is located from whatever place you but the new element from.
Anonymous
  • Posted on Jan 19, 2010
SOURCE: Error code E6 on a Whirlpool Duet Dryer
Whirlpool Duet electric dryer only dries clothes on heavy duty selection. what is wrong?
Anonymous
  • 43501 Answers
  • Posted on Apr 06, 2010
SOURCE: whirlpool duet GEW9250PW1 electric dryer squeals
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Testimonial: "Thanks, so now how do I get the extended warranty plan to pay for it. They will not send someone out for squeaks and squeals. "
1helpful
My Whirlpool duet dryer isn't drying on automatic or timed settings. I replaced the ther-o-mister, but the dryer isn't heating up. How do you run a diagnostic on this dryer. Model GEW9250PWO
You should know that dryer has a thermal fuse located along exhaust Of heat... When You over load the machine the flow of air is not enough... Then thermal fuse is damaged ( open due security condition ) and the flame is turn off all the time... Just replace the thermal fuse. I hope this can help You. Sincerely
Jul 10, 2013 • Dryers
1helpful
My whirlpool duet dryer works but it appears that the air is not evacuating from the baril. The heat and humidity built up and the clothes don't dry. Do I need to replace the fan and if so, how
YOU NEED TO CLEAN THE VENT ON YOUR HOUSE IF THE BLOWER WHEEL IS BAD ON THE DRYER YOU WOULD HERE THE NOISE AFTER THE DRY STOPS THE BLOWER WHEEL WILL STILL TURN AND MAKE A NOISE
4helpful
Whirlpool duet GEW9250PW1 electric dryer squeals
heatman101
Gas dryer heating element won't come on.
There is a controller problem to turn on the gas manifold to produce heat. Since you have it only one week old, let's take the advantage of the warranty to have a new controller unit replaced.
4helpful
8helpful
Whirlpool duet front loader dryer....sensing light won;t shut off
I have a whirlpool electric dryer and it cuts off and shows E 1... What is the problem?
Duet gas dryer shuts off after 15 min
I cleaned out the vent that was clogged pretty good, put dryer back together (a solution I read in this blog), and now it is working fine. I was testing with bottom open.
My Whirlpool duet dryer is getting too hot
YOU NEED A NEW THRMO KIT
STEVE'S APPLIANCE
516-300-3249
Dear Customer
Top Whirlpool Dryers Experts
Virgil Watts
Paul Bade
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
