Sony Bravia L-series Kdl-32l5000 32-inch 720p Lcd Hdtv, Black Logo
Freddy Pagan Posted on May 06, 2014
Horizontal lines flickering at the bottom of screen...... SONYbrvia KDL-32L 5000
1/3 of screen video is ok 2/3rds of the screen have horizontal flickering lines,soun is ok.
rivsy
Level 1:
New Friend:
  • Contributor 23 Answers
  • Posted on May 06, 2014
rivsy
Contributor
Level 1:
New Friend:
Answers
23
Questions
0
Helped
3785
Points
47
Hi Freddy Pagan
I like your Sony TV is defective that it cannot be fix again, better call the Customer Support to replace your Sony TV.
I hope my solution may help you.
Thanks for using Fixya...;-)
2answers
LG OLED Horizontal Flickering + Power off
The model would have helped. Generally horizontal lines in the picture come from a defective panel and the set isn't fixable, you could try replacing the t-con board but chances of fixing it are slim
1helpful
Samsung 5271f. Picture usually great but sometimes when an image with horizontal lines appears (e.g. crawl at the bottom of the screen) picture jumps and flickers. Reverts back after crawl disappears.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
1helpful
I have intermittent horizontal lines covering the whole screen. Sometimes it flickers and sometimes the lines are ghost images. When the lines are black they tend to be thickest at the right and almost...
That's a problem. If it's still in warranty you're in luck. Either take it back to the store, or call Sony to have it repaired under warranty. If it's out of warranty they can send a third party servicer to your home to the tune of $400 labor (in 2008) plus parts in the US. I will say this much, if it turns out to be an LCD panel issue, the panel will cost about the same as the TV itself when it was new.
The issue you describe sounds like the scan frequency isn't right for the video you are watching. In other words, it should be 720P and it is running at 1080P instead, and you wind up with a horizontal fold-over type of line.
That makes that new OLED TV a little more enticing!
I have a Bravia KDL 40BX421 that suddenly has green vertical lines on the bottom 1/4 of the screen. These lines are in a background bar that is mostly a reddish shade.
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/.../1127410-thin-vertical-lines-cover-screen-samsun...
Mar 7, 2009 - 30 posts - ‎25 authors
Hi guys, Ive had this TV for about a year now - all of a sudden thin vertical lines havecovered my screen (show in link below) No matter what ...Missing: 40bx421
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... hi i have a sony bravia mdel # KDL46EX523. i have horizontal multi colored lines ... My TV has the following symptoms: - Horizontal lines from top to bottom of .... thick(like 1-1/12 inch) and a couple of green vertical lines next to the black one.Missing: kdl ‎40bx421
Flat Screen TV Has Lines Going Through Screen - Possible ...
Re: KDL-40S2000 black horizontal lines
If you have a horzontal black line (left to right) panel is bad.
Benq w5000 green horizontal line flickering at bottom of screen
Hi there
This is normally only one of two things : Cable or Mainboard
The W5000 is quite a new Projector and should still be under warranty.
But try changing the cabling first and if the problem still persists , let BenQ replace the Mainboard.
Video flickering
Horizontal lines are either caused by the main logic board, a dammaged screen or by the main x and y drivers. Hard to determine which one it is, but somthing is getting hot which is causing the problem. My guess is the main logic board.
Line in picture
Send me a Digi-pic of the screen please.. Good starting point..
[email protected]
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
