Mercedes C-class C230 C240 C350 C55 Exterior Stainless Steel Chrome Pillar Posts Trim Set 2005 2006 2007 Logo
M
Mike Posted on Apr 30, 2014
Right Rear door and right roof airbag blown , do I need the replace or rest the control module after replacing the blown airbags and where is the airbag control module located?
Right Rear door and right roof airbag blown , do I need the replace or reset the control module after replacing the blown airbags and where is the airbag control module located?
Bart Hout
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on May 08, 2014
Bart Hout
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
Helped
1417
Points
11
Yes the airbag module must must always be replaced. Its most likely located under the mid console. Not sure about location
1helpful
2020 Chevy Tahoe Z71. Do I need to replace my airbag module?
Question edited for clarity, 'year make model' first.
This is one job, I would not do myself. The airbags are extremely dangerous if they go off, even if just reconnecting the battery. I would replace the impact sensors. Not sure if they are resettable, but I would replace anyway.
Often, having the sensors reset and recalibrated is adequate. However, when the airbag does deploy, there's more to do than just replace the airbag.
May 4, 2017
The importance of recalibration after airbag deployment
https://www.google.com/search?q=2020+chevy+tahoe+z71+airbag+crash+sensor
ARE THE AIRBAGS ON THEIR WIRING CONNECTED TO THE JUNCTION 'FUSE BOX?? PLEASE HELP
He is slightly wrong. There is a fuse that powers the airbag control module. But that is it, there would be a different code if the junction fuse box was the problem to that airbag light.
B1382 Side Airbag Front-Passenger Resistance too High
Possible causes:
  • Side airbag disconnected.
  • Damaged wiring to airbag.
  • Faulty airbag.
  • Faulty airbag control module.
2answers
How many airbag sensors in a 2008 gmc acadia
1) Front End Sensor - Right--Located under the front hood in the engine compartment (2) I/P Air Bag--Located at the top right under the instrument panel (3) Roof Rail Air Bag - Right--Located under the headliner, extending from the passenger front windshield pillar to the passenger rear windshield pillar (4) Side Impact Sensor (SIS) - RF--Located under the right front door trim near the lower rear of the door frame (5) Sensing and Diagnostic Module (SDM)--Located underneath the vehicle carpet under the center console (6) Seat Belt Pretensioner - RF--Located under the trim near the bottom of the center pillar (7) Side Impact Sensor (SIS) - RR--Located under the right rear door trim near the lower rear of the door frame (8) Roof Rail Module - Right--Located behind the garnish molding on the upper rear pillar (9) Roof Rail Module - Left--Located behind garnish molding on the upper rear pillar (10) Side Impact Sensor (SIS) - LR--Located under the left rear door trim near the lower rear of the door frame (11) Seat Belt Pretensioner - LF--Located under the trim near the bottom of the center pillar (12) Side Impact Sensor (SIS) - LF--Located under the left front door trim near the lower rear of the door frame (13) Roof Rail Air Bag - Left--Located under the headliner, extending from the driver front windshield pillar to the driver rear windshield pillar (14) Steering Wheel Air Bag--Located on the steering wheel (15) Vehicle Battery--Located at the front left of the engine compartment. (16) Front End Sensor - Left--Located under the front hood in the engine compartment
How do i reset my deployed headrest in my crystler 200 i was rear ended
There is no resetting a deployed airbag. The air bag module must be replaced and the airbag control module will need replacing along with the seatbelt pre-tensioners.
Left rear door airbag and leftside roofaibag poped and the right rear safetybelt damaged. Do we neat to replace all the airbags ,safetybelts ,sensors and the controll unit?
not normally the controll unit yes and the poped air bags but the rest will be ok the controll unit stores any accidents and will have to be replaced it cannot be reset
3helpful
2001 pontiac grand am air bag module reset
Yes!!! You can replace it yourself.(Dont let others fool you into paying extra or telling you otherwise.)
-This is for pontiac grand ams 1999-2005 only.
-There are no frontal airbag impact sensors nor are there belt tensioners.
-The SRS system consists of only the (driver airbag) ,(passanger airbag),and the (airbag control module) in 1999-2005 grand ams.
If you crash/wrecked and airbags deployed you will need.
-Driver and Passanger airbags
-Airbag control module
You can buy cheap airbags from a local junkyard any year from 1999-2005 will fit.
You can also find an airbag control module for cheap at your local junk yard BUT YOU MUST FIND ONE WITH THE SAME (PART NO.) AND (SERV NO.) AS THE ONE YOUR REPLACING.The (part no.) and (serv no.) should be at top left of airbag control module.However it does (Not) have to match numbers under barcode or the numbers at the far bottom right of airbag control module.
After you get both airbags and airbag module
-Disconnect car Battery
-Replace airbags
-Replace airbag module (under passanger seat)
-Double check all connections and connect battery.
Congradulations!Your airbags should be back online.
Notes: Two torx 35 head screws hold the driver airbag, access is through two holes behind steering column.
To remove passanger airbag you have to remove glovebox it uses (7mm)screws.After you remove you will see a pair of (10mm)screws holding airbag.
To remove airbag control module First remove passanger seat 2(15mm).Then after removing you will notice a raises area kinda like a vertical bump.Take a razor blade to your carpet and cut it to explose the module underneath.
The airbag module is held by three screws depending on the year of your car it varies.Most likely 3 (10mm).
4helpful
Schematic to driver side fuse box
Cavity Fuse Description
1) 15 Amp Blue Horn Relay, Power Sunroof
Relay, Power Window Relay
2) 10 Amp Red Rear Fog Lights (Export Only)
3) 20 Amp Yellow Cigar Lighter
4) 10 Amp Red Headlight Low Beam Right
5) 10 Amp Red Headlight Low Beam Left
6) 20 Amp Yellow Body Control Module/Power Door Locks
7 )10 Amp Red Left Park Light/Left Tail Lamp/License Plate Lamp
8) Spare
9) 10 Amp Red Right Park Light/RightTail Lamp/License Plate Lamp/Cluster
10) Spare Cavity Fuse Description
11) 15 Amp Blue Flasher
12) 15 Amp Blue Stop Lights
13) 10 Amp Red Body Control Module/CMTC/Cluster/Pass. Airbag On,Off Indicator, Auto Daylight
Mirror/Light Bar Switch (Renegade Only)
14) 10 Amp Red PDC Fuel Pump/AC Clutch,
Starter Relay/Engine
Controller/Transmission
Controller (Diesel Only)
15) Spare
16) 20 Amp Yellow Power Outlet (Rear)
17) 15 Amp Blue Rear Wiper
18) 20 Amp Yellow Radio Choke & Relay
19 20 Amp Yellow
Frt Fog Lights/Trailer Tow
Stop and Turn Lights
20 Spare
21 10 Amp Red Radio
22 20 Amp Yellow
Power Sunroof Relay/
Antenna Module (Export
Only)
23 Spare
24 10 Amp Red PDC Blower Motor
25 10 Amp Red Heated Seat Switches/HVAC
Control Head/Trailer Tow
Battery Charge
26 10 Amp Red Headlight High Beam Right
27 10 Amp Red Headlight High Beam Left
28 Spare
29 10 Amp Red Heated Mirrors/Rear Window
Defroster Indicator
30 15 Amp Blue Heated Seat Module
31 Spare
32 10 Amp Red Wiper Switch/Front and
Rear Wipers
33 10 Amp Red SKIM Module/Data Link
Connector
34 15 Amp Blue Body Control Module/
Cluster/Interior Lights,
Hands Free Module/Radio/
CMTC/ITM Module & Siren
(Export Only)
35 Spare
36 10 Amp Red Airbag Control Module/
Occupation Classification
Module (Right Front Seat)
37 10 Amp Red Airbag Control Module
38 10 Amp Red ABS Controller/Shifter Assembly
39 10 Amp Red Hazard Flasher (Turn
Signals)/Backup Lamp
Switch (Manual Transmission
Only)/Transmission Range
Switch (Automatic Transmis
1helpful
Main fuses for the horn and air bag
Fuse #8, #18 and #22.
Below is a listing of which fuse corresponds with which circuit:
1 - 10 Amp - Transmission Controller, Gauges, Autostick
2 - 10 Amp - Right High Beam Headlight
3 - 10 Amp - Left High Beam Headlight
4 - 10 Amp - Radio, CD Player
5 - 10 Amp - Washer Motor
6 - 15 Amp - Power Outlet
7 - 20 Amp - Tail, License, Parking, Illumination Lights, Instrument Cluster
8 - 10 Amp - Airbag
9 - 10 Amp - Turn Signal Lights, Turn Signal/Hazard Indicator
10 - 15 Amp - Right Low Beam
11 - 20 Amp - High Beam Relay, High Beam Indicator, High Beam Switch
12 - 15 Amp - Left Low Beam Headlight
13 - 10 Amp - Fuel Pump Relay, Power Train Control Module
14 - 10 Amp - Cluster, Day/Night Mirror,Sunroof, Overhead Console, Garage Door Opener, Body Control Module
15 - 10 Amp - Daytime Running Light Module (Canada)
16 - 20 Amp - Fog Light Indicator
17 - 10 Amp - ABS Control, Back Up Lights, Daytime Running Lights, A/C Heater Control Cavity Fuse Circuits
18 - 20 Amp - Power Amplifier, Horn
19 - 15 Amp - Overhead Console, Garage Door Opener, Trunk, Overhead, Rear Reading, and Visor Vanity Lights, Trunk Release Solenoid, Power Mirrors, Power Door Locks, Body Control Module, Aspirator Motor
20 - 20 Amp - Brake Lights
21 - 10 Amp - Leak Detection Pump, Low Rad Relay, High Rad Relay, A/C Clutch Relay
22 - 10 Amp - Airbag
23 - 30 Amp - Blower Motor, ATC Power Module
24 - 20 Amp - Power Window Motors
25 - 20 Amp - Power Door Lock Motors, Power Seats
2helpful
I need to replace the srs (airbags) 2002 mustang
U can't just do the bags, u will need to replaced the control module/diagnostic module and test and replace any affected crash sensors, all this requires electrical test equipment an allot of field tech experience, also if not done right u can cause the airbag to go off and really hurt yourself.
Top Mercedes-Benz Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
ADMIN Andrew
ADMIN Andrew
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
