20 Most Recent
Mercedes C-class C230 C240 C350 C55 Exterior Stainless Steel Chrome Pillar Posts Trim Set 2005 2006 2007 Questions & Answers
2006 Mercedes c230 intake manifold torque specs and procedure
You can find the info you are looking for in a repair manual, such as Chilton, Haynes, etc.
If a repair manual is not available, the local garage or dealership can provide you with the info, with their database from MotorAll Data, ShopKey, etc.
Check the library to see if they have the resources, such as the repair manual, or online database to, MotorAll Data, ShopKey, etc.
Have a nice day.
Car cranks but will not start
Maybe you're looking in the wrong area. You said it started to idle rough and kept shutting off. That could also be a fuel related issue. Possibly a clogged fuel filter or weak fuel pressure from the pump going bad. Check your fuel pressure. If you discover that the fuel pressure is correct, then make sure you have a strong blue colored spark from each coil by taking a good plug and plugging it into each coil while its out of the cylinder. Have someone spin it over and watch the color of the spark. A dull orange colored spark could mean bad coils or even the computer itself.
Key will not turn in the ignition
Disconnect the battery for 10 minutes incase the battery charger messed with the computers in the car.Always disconnect the battery before charging it on modern vehicles (especially German Vehicles) as things like this happen.
P 2096 CODE MERCEDES ML 320
The causes for this DTC may include: Low fuel pressure caused by a clogged filter, failing fuel pump, failed fuel pressure regulator or clogged or leaking injectors. Rough running engine due to misfiring plugs. Many engines have misfire codes to indicate the cylinder effected, such as P0304 for number 4. A large vacuum leak would cause a massive amount of un-metered air to enter the intake manifold resulting in an overly lean mixture. A large air leak at or near the number one oxygen sensor would also cause a lean mixture. A plugged converter will cause of host of driveability problems as well as set this code. A severely plugged converter will result in the inability to increase rpm when under load. Look for a code such as P0420 -- catalytic converter efficiency below threshold if the converter indicating a faulty converter. A faulty oxygen sensor. This will set a code in itself, however, a faulty oxygen sensor does not automatically condemn the sensor. The code just means that the sensor signal was not within specifications. An air leak or any of the above will cause an erroneous signal. There is a multitude of O2 codes relating to O2 performance which gives a clue to the problematic area. The Mass Airflow sensor will also cause this problem. It would be accompanied by a code such as P0100 -- Mass Airflow circuit malfunction. The Mass Airflow sensor is a hot wire that senses the volume of air entering the intake manifold. The computer uses this information to control fuel mixture. Rusty exhaust systems, cracked exhaust manifolds or damaged or missing gaskets or donuts will cause air leaks. If you need further help, reach me via phone at
https://www.6ya.com/expert/david_1f7d1c330c9dd97d
UNLOCK CODE
Look in your glove box in the owners manual or with the papers you got when you got the car, and see if you have a card or a piece of paper that tells you what the code is. If not you will have to call your local mercedes dealer and give them your vin/serial number and they can look it up for you. If you need further help, reach me via phone at
