It's a three prong setup and I have a red wire and 2 black wires the two black ones come are connected to the same prong
SOURCE: On an E 100 Razor scooter, the battery charger shows charged
We had the same problem that I found to have a very simple fix. It seems all that needed to be done was hold in the reset button a few seconds while the battery charger was plugged in and the light on the charger turned to red and the battery charged again. Seems like too easy of a fix but it worked for my kids scooter.
SOURCE: Bought a new battery for
take a look at the other one and see on which side the wire was hooked..on +or - or both where ...and just get some wires if they need to be longer ..and hook it in the same screw with the normal power line ..but remember from the other one ..which and where ..
SOURCE: razor e300 scooter charger light stays green,
I have this same problem? What do you do? I bought a new charger thinking it was that and the light stays green on it too.
SOURCE: Almost new..three recharges...was working fine,
After charging use a voltage tester to measure the voltage from the battery the reading must be equal to what is the voltage output of the battery 12v or 24 volts if you can measure the correct out put voltage then the battery is full charge the scooter should work well.
If you measure a low voltage means you need to full charge first the battery before operating.
to measure the battery voltage put your red test prove to the positive terminal of the battery (red)and black test prove to the black terminal of the battery....If the battery is full charge and the scooter wont run there is a problem on the motor cleaning the carbon brush of the motor will solve the problem...
good luck!if you need further assistance just post back!
SOURCE: how to remove rear tyre from e300 electric razor
Regards,
Tomy
Testimonial: " that tells me how to remove the weel but not the tyre but thank you anyhow "
